Gen4 Jimny Transfer Box - New technical bulletin - Q-A6G-008
13 Sep 2022 16:28 - 14 Sep 2022 11:09 #244954
New bulletin just out - Q-A6G-008
This replaces bulletin Q-A6G-004
It is described as being "ADDITIONAL MEASURES TO Q-A6G-004" which implies that it further improves on Q-A6G-004 and therefore may improve vehicles that still have the problem after the original Q-A6G-004 has been carried out.
Key difference is the part number for the transfer chain has changed, implying that they have changed the chain again.
As the older Jimnys are now 3 years old be aware that your warranty is expiring
I also note that there is an update to the Bosch SDLA entertainment unit which fixes a bug where after the unit is turned off with a USB device connected it may continually reboot on the next power on and also a fixed for a French language translation issue.
JUST TO UPDATE AND MAKE CLEAR: THIS IS NOT RECALL - it is a repair on report only. You have to have the fault on your vehicle, it has to be diagnosed by the dealer and then you put it in for repair which will be under warranty if your car is within the warranty period.
Last edit: 14 Sep 2022 11:09 by mlines.
13 Sep 2022 17:55 #244958
by fordem
Replied by fordem on topic Gen4 Jimny Transfer Box - New technical bulletin - Q-A6G-008
Can you share the updated part number for the chain - thanks in advance.
13 Sep 2022 19:41 #244959
Replied by mlines on topic Gen4 Jimny Transfer Box - New technical bulletin - Q-A6G-008
29200-78R20
13 Sep 2022 20:59 #244960
by crash486
Replied by crash486 on topic Re:Gen4 Jimny Transfer Box - New technical bulletin - Q-A6G-008
I get the chain harmonic noise in 1st and 2nd gear after having the original chain replaced.
I hope my dealer will try this on my TC.
Thanks for the information Martin.
crash486 JB74W
crash486 JB74W
14 Sep 2022 00:22 #244962
by fordem
Replied by fordem on topic Re:Gen4 Jimny Transfer Box - New technical bulletin - Q-A6G-008
Thanks much
14 Sep 2022 08:55 - 14 Sep 2022 09:00 #244964
by lightning
Replied by lightning on topic Re:Gen4 Jimny Transfer Box - New technical bulletin - Q-A6G-008
Ours is on 10,500 miles and the transmission has been silent.
However it's only been driven on road and we've not used the 4wd or low range (except to test it) don't know if that makes any difference.
The dealer changed the transmission oils at the first service when it had only done about 3,000 miles because they said it was a "good idea"
l assume they used Suzuki specification oil as it's a Suzuki dealer.
Last edit: 14 Sep 2022 09:00 by lightning.
Time to create page: 1.378 seconds
