My radio antenna snapped off...
- Sirjamesrusty
Topic Author
- Junior Member
- Thank you received: 1
31 Aug 2022 21:53 #244821
by Sirjamesrusty
I'm starting my Jimny experience as a complete novice on a 2008 Jimny VVTS...
My radio antenna snapped off... was created by Sirjamesrusty
In the last storm we had my telescopic radio antenna snapped off (I still have the antenna) It doesn't seem to want to slot back in at all and I've unscrewed the mount on the drivers side of the roof but can't work it out. I'll post a few pics in the morning light again... What should I buy in order to replace the antenna with a new one? - Got a week off work next week and looking to get a few jobs done on the Jimny, hence a few posts. Thanks again...
01 Sep 2022 01:54 - 01 Sep 2022 01:59 #244822
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic My radio antenna snapped off...
I think this is a direct replacement for the jimny.
eBay item number: 403798064102
I replaced mine a few years back after I reversed into a low hanging branch.
For some reason, I can't get the ebay link to appear here using the ebay tags.
Last edit: 01 Sep 2022 01:59 by Mike G.
The following user(s) said Thank You: Sirjamesrusty
- Thank you received: 1983
01 Sep 2022 04:23 #244824
Replied by Lambert on topic My radio antenna snapped off...
I replaced my last one with the dealer part, cost less than 20 quid. Just remember to firmly attach a string to the end of the cable you are replacing then you can use it to fish the new cable back through.
- Rothbury1
01 Sep 2022 04:25 #244825
by Rothbury1
Replied by Rothbury1 on topic My radio antenna snapped off...
Hi, i have had similar with vandalism and low garage doors.
My advice is buy a new aerial.
Get under the dash and find the connection to the radio and disconnect, DO NOT pull the old aerial wire yet
Now attach a length of wire or strong cord with electrical tape to the detached old aerial, tapered for a few inches either side of the join,
When your satisfied the join is secure, pull the old aerial up and out, it is easy with two people, one pulling and the helper feeding the wire up but doable solo.
Now disconnect the old aerial from the draw wire, and attach it to the new aerial. Next, pull down the draw wire from under the dash and feed it down from the top pulling the new one back down.
Reconnect the new aerial wire to the radio and secure the unit on the roof ensuring it is leak proof.
Hope this helps.
Hope this helps.
- Sirjamesrusty
Topic Author
- Junior Member
02 Sep 2022 06:29 #244835
by Sirjamesrusty
Replied by Sirjamesrusty on topic My radio antenna snapped off...
Thanks all for that - I've just watched a good YouTube video on the fishing the wire exercise. I'll give that a go when I get the parts ordered.
Cheers,
Chris.
Cheers,
Chris.
