Are shock extenders supposed to swivel?
30 Aug 2022 12:06 #244786 by Fifo
Hello lads,
I've recently purchased a gen 3 jimny, and the previous owner has fitted it with a 2" lift. He used coil spacers and shock extenders instead of replacing them with longer components. I'm aware that this is not the best lifting solution, I might change them later, but it is staying there for now.
Anyways are the extenders supposed to swivel along the lower bolt, where previously the shocks eyelet was? In my car they seem to be bolted rigid, tried turning them and they didn't bugde.
30 Aug 2022 13:14 #244787 by fordem
Maybe post a picture of what you have - I've seen different styles of shock extender and in most cases you wouldn't want them to swivel at least not after they have been installed.
30 Aug 2022 15:19 #244792 by Fifo
Sure thing, here's a picture of the rear shock extenders.
I was actually leading up to this next question. I'm still learning about car mechanics but the alignment of the shocks and extenders doesn't seem too good to me. I wasn't sure whether the extender was supposed to rotate or not, and just happened to end up in that position, or if it was probably installed improperly.
30 Aug 2022 15:34 #244795 by fordem
I wouldn't worry too much about the misalignment there - it's caused by the rubber bush in the shock eye flexing. You could probably loosen the bolt and straighten it up, but I suspect it'll just shift itself over again.
The following user(s) said Thank You: Fifo
30 Aug 2022 16:17 #244797 by jackonlyjack
Never had that issue when i had some on mine
I would say loosen the bolt and see if it moves to line up with bottom of shock
31 Aug 2022 09:52 #244805 by Fifo
I see, thank you for the info. I think I'll try to align but even if it shifts back it is good to know that it's all good.
Time to create page: 0.284 seconds
