Will Wheels Designed for Newer Jimnys Fit a 1997?
27 Aug 2022 19:57 #244766 by fordem
I believe -5 is the offset of the OEM rims, so you should be fine with those rims, as long as you don't go overboard on the tire size.
Regarding that suspension lift - a four inch lift sounds quite extreme. If the JA22W uses the same (or a similar) coil spring setup as the JB43 & JB74, you'll probably need some sort of caster compensation so it might be an idea to make sure the kit includes it.
28 Aug 2022 03:25 #244768 by Lambert
All factory wheels are positive 5 offset.
29 Aug 2022 19:00 #244778 by jackonlyjack
The bronze wheels will fit just fine on your ja22
what tires you going to fit
ps wish i could get 16 x 5.5 over to UK without costing an arm and a leg
01 Feb 2023 08:46 #247312 by Bosanek
Can someone confirm if the data in the wiki about Jimny wheel offsets is correct:
www.bigjimny.com/mediawiki/index.php/Tyr..._wheel_specification
It currently states ET22 for Jimny 3 steel and alloy OEM wheels, but ET5 for Jimny 4 steel and alloy wheels.
Correct or not?
What should be written there?
01 Feb 2023 12:07 #247315 by Busta
Me too Jack, I'm still looking...
01 Feb 2023 15:29 #247318 by Lambert
My gen3 alloys are definitely et5 it's cast into the wheel on both my sets.
The following user(s) said Thank You: Bosanek
Time to create page: 0.447 seconds
