1 wheel drive. whats wrong?
- g4vcn
11 Dec 2010 11:45 #7330
by g4vcn
Replied by g4vcn on topic Re: 1 wheel drive. whats wrong?
Ok. I have the other side striped down. The cv is a bit still but the main thing that has caught my eye is when i look through the hole the drive shaft goes in. There is a cog that is moveing all over the place when i turn the prop by hand. That isnt right is it. It almost lifts up to a point then just drops back to the bottom of diff as im turning prop.diff fkd?
Gav
Gav
11 Dec 2010 11:53 #7333
by facade
Replied by facade on topic Re: 1 wheel drive. whats wrong?
Doesn't sound right.
Pull the other driveshaft, remove the front prop and the bolts around the diff, and it will come out.
If you are lucky the pin through the planet gears has dropped out, and it will go back together.
Surprised if the front diff has broken, they don't get much use.
- g4vcn
11 Dec 2010 13:29 #7338
by g4vcn
I have removed the diff and it is in 8 pieces.It is truely foooooked. I will put some photos on later. I need a new diff. Where can i get one from? Any one have or know of someone who has one? Its a 09 plate jimny with the eletric 4wd buttons. Please help
gav
gav
11 Dec 2010 16:09 #7346
by facade
Try ringing round the breakers Cam Suzuki for example.
I should think they have loads of front diffs, unless they sell the front axles complete.
I would expect a rear diff will fit, and they are stronger, 4 planet gears not 2.
- g4vcn
11 Dec 2010 17:50 - 11 Dec 2010 18:05 #7348
by g4vcn
does anybody know if i could use any front diff from a jimny or does it have to be an exact one??
are there any other suzuki breakers other than cam suzuki??
gav
gav
Last edit: 11 Dec 2010 18:05 by g4vcn.
- g4vcn
11 Dec 2010 18:06 - 11 Dec 2010 18:16 #7349
by g4vcn
This is what i found ...
Attachment diff3.jpg not found
Attachment diff2.jpg not found
Attachment diff.jpg not found
Last edit: 11 Dec 2010 18:16 by g4vcn.
Time to create page: 0.170 seconds
