Oil dripping around gear shaft
  • Sharik
25 Jun 2022 15:34 #243820 by Sharik
Oil dripping around gear shaft was created by Sharik
I have no idea from where oil is drippin. It seems it going from this shaft near gear stick. I never knew there is oil inside.
26 Jun 2022 10:45 #243830 by bryn
Replied by bryn on topic Oil dripping around gear shaft
Could be drive shaft oil seal where the drive shaft enters the gear box. A reasonably easy job to replace.
Bryn
08 Jul 2022 07:36 #243995 by BertieR
I have this problem for a long time . Replace the shaft seal a couple of times with no success.  Replace the sleeve also no success.  Find out later the oil come from the rear side of the yoke that go into the gearbox on the drive shaft. Sealed it and gone is the leak.
Time to create page: 0.275 seconds
