Lack of hot air when heating is on full-blast?
14 Jun 2022 21:03 #243706 by Darthblaker7474
Hello! I was wondering if you can help me.
I recently got my Jimny back on the road and the heater was working fine until a few weeks ago when I noticed it won't put out hot air on anything above the lowest setting. The engine gets up to temperature normally, and apart from that it seems to run fine, AC is also ice-cold.
I suspect it may be the resistor in the blower motor as I've had this happen in the work's van before, and I believe this to be the problem
Any help is appreciated thank you !
14 Jun 2022 21:09 #243707 by mlines
I would look underneath at the little white levers on the end of the selector cables. Often the wire has come off
Sent from my moto g42 using Tapatalk
16 Jun 2022 20:36 #243733 by Darthblaker7474
Are these located on the left of the driver's side footwell?
16 Jun 2022 20:46 #243734 by mlines
And the right side of the passenger field as well.
Move the heater controls whilst looking down each side
20 Jun 2022 13:12 #243774 by DrRobin
How full is the coolant, is it going down? The heater matrix can be one of the first things to empty when there is a leak, especially if the leak is in the heater itself.
Time to create page: 0.198 seconds
