Lack of hot air when heating is on full-blast?
- Darthblaker7474
Topic Author
- Elite Member
- Thank you received: 37
14 Jun 2022 21:03 #243706
by Darthblaker7474
Lack of hot air when heating is on full-blast? was created by Darthblaker7474
Hello! I was wondering if you can help me.
I recently got my Jimny back on the road and the heater was working fine until a few weeks ago when I noticed it won't put out hot air on anything above the lowest setting. The engine gets up to temperature normally, and apart from that it seems to run fine, AC is also ice-cold.
I suspect it may be the resistor in the blower motor as I've had this happen in the work's van before, and I believe this to be the problem
Any help is appreciated thank you !
14 Jun 2022 21:09 #243707
Replied by mlines on topic Re:Lack of hot air when heating is on full-blast?
I would look underneath at the little white levers on the end of the selector cables. Often the wire has come off
Sent from my moto g42 using Tapatalk
- Darthblaker7474
Topic Author
- Elite Member
16 Jun 2022 20:36 #243733
by Darthblaker7474
Replied by Darthblaker7474 on topic Lack of hot air when heating is on full-blast?
Are these located on the left of the driver's side footwell?
16 Jun 2022 20:46 #243734
And the right side of the passenger field as well.
Move the heater controls whilst looking down each side
- Darthblaker7474
Topic Author
- Elite Member
20 Jun 2022 12:02 #243772
by Darthblaker7474
- Thank you received: 663
20 Jun 2022 13:12 #243774
Replied by DrRobin on topic Lack of hot air when heating is on full-blast?
How full is the coolant, is it going down? The heater matrix can be one of the first things to empty when there is a leak, especially if the leak is in the heater itself.
Time to create page: 0.221 seconds
