Re:Roof racks
- Ron0z
The last roof rack I came across was around the mid '80s and it had four brackets (nut and bolt fixing) that hooked under the roof gutter. The gutter in older cars is pretty solid: that's where the roof and sides panels of the car come together and are spot welded and bent upward to catch water from the roof. So, not only does the bend lend itself to adding strength the material is twice as thick as most other parts of the car. It naturally lends itself to supporting loads.
So, are modern roof racks (which are designed for cars with no gutter) held on by a few self-tapping screws? That'd be a damn scary thought.
- Thank you received: 227
If you want a rack, the best thing would be to mount it to the studs and keep the weight 30ish kg.
- Thank you received: 1999
Nice work Lambert,another great idea I'm going pinch from you, i guess farmers the world over are innervatorsLambert wrote: I have replaced my plastic longitudinal bars for steel transverse ones using the existing roof studs. I use them regularly on the farm to move long items that won't go inside like feed troughs. You can definitely feel the weight up high. I went for 2 simple bars rather than some kind of platform or basket because for my use anything on the roof is self supporting and a basket or platform is dead weight. It's worth noting that my bars might weigh 2.5kg between them but some of the platforms especially the modular design type can be getting close to 30kg on their own. It's very easy to overload a jimny without trying and once they are they really let you know about it.
Sent from my SM-A336E using Tapatalk
Did you make the brackets between the studs and bars yourself Lambert?
I now got the original rails and some prorack bars that fit in between the rails.
looks ok and they can take the planks I need for my projects. (not a farmer but still..)
