225/70r15 on Jimny with facelift bumper (2007)
  • 8ollins
19 May 2022 21:50 #243370 by 8ollins
I am looking at some 225/70/15 Maxxis AT-771. 2007 Jimny meaning it has got the big bumper. Also looking at some 15"x7" wheels (ET-0). Will this fit with a perfectly stock Jimny?
Apologies as this is probably asked multiple times a day
20 May 2022 03:29 #243372 by Lambert
I don't have direct experience of that exact combination of wheel and tyre but I suspect it will be quite tight but should clear. A 235 75 on a factory wheel is about as big as you can go but that's for gearing and depending on the exact tyre will need some clearance work. You propose a narrower and shorter tyre but on a wider rim with more back space. I guess at worse it's just a plastic trim that will rub possibly?
The following user(s) said Thank You: 8ollins
Time to create page: 0.136 seconds
