Stereo Woes
- spookyandroid
19 May 2022 07:41 #243358
by spookyandroid
Stereo Woes was created by spookyandroid
Hi everyone - new Jimny owner here.
Bought a 54' online from a garage, knew it needed a bit of TLC but the list is growing by the day. Don't think id have bought it if this was the case.
So far:
Front DS kingpins - done
Front discs and pads - done, fitted new calipers for measure too.
Replaced interior due to a distinct weed smell - didnt know this til i picked it up - done
Fix 4WD system - not done
Fix lumpy idle - done
and much nore anyways decided I wanted a decent head unit in there, as the existing one was basic albeit, it worked.
I have tried 3 different double din head units, all suffering from the same issue, working, but no audio. The old Sony single din head unit works without issue.
After trying two crappy chinese android head units, i decided they must just be garbage and bought a double din Sony HU, thinking atleast it will be compatible. Nothing, no audio.
After much tinkering, if I connect the blue and white "ATT" wire to the red "ACC" wire, I can get audio, but only when I've put the key into ACC and then turned it back to "OFF".
As stated, the previous Sony head unit works without any issue, and only works when the ignition is on. So I dont think its the ignition barrell.
Any insight into this mystery would be very much appreciated.
Danny
So far:
Danny
- Thank you received: 1999
19 May 2022 09:13 #243359
Replied by Lambert on topic Stereo Woes
Welcome to the forum. From memory blue and white is usually illumination yellow and black is usually attenuation of mute. Either way a Sony should be wired to ISO standard plugs power and output. So it should be possible to either get an adaptor to the Jimny if it's still got it's factory plug or if not then to reverse isolate the existing wires to their corresponding ISO standard positions. Would you be able to post a picture of the wiring in the dashboard?
- spookyandroid
19 May 2022 09:40 - 19 May 2022 09:45 #243361
by spookyandroid
Replied by spookyandroid on topic Stereo Woes
Thanks for the reply Lambert.
I'm normally OK at this sort of thing, but I must admit it's got me stumped. I thought the black cable was the ground though?
Here are some photos, Tried my best to photo each section as clearly as possible. This is the head unit that is working, if you want pics of different adaptors lemme know.
Thanks,
Danny
Thanks,
Danny
Last edit: 19 May 2022 09:45 by spookyandroid.
19 May 2022 11:15 #243363
Ok first thing it's not being butchered which is a good thing. What this means is that you can now look up the correct colour and position diagram and work from there. Unfortunately I am at work and even then I don't have a diagram to forward. The only thing I can see is that it looks like someone has patched in a switching feed for an amplifier other than that it's just a matter of confirmation of wire position to function with a multimeter.
The following user(s) said Thank You: spookyandroid
- spookyandroid
19 May 2022 11:48 #243364
by spookyandroid
By switching feed, is that the blue cable coming from the cig lighter into the cable higher up?
It's a little over my head really, is the next port of call an auto electrician?
- Thank you received: 667
19 May 2022 12:42 #243365
Replied by DrRobin on topic Stereo Woes
When I fitted my Android head unit, one of the wires on a 2011 Jimny was in the wrong place. I have forgotten which one, but it was an important one.
Which head unit are you now trying to fit? If you have a model number or better still a wiring diagram I can check to see if the ISO plug matches the Jimny.
Time to create page: 0.205 seconds
