Door remote fob - is it voltage sensitive?
- gecwhiz
31 Mar 2022 15:52 #242637
by gecwhiz
Door remote fob - is it voltage sensitive? was created by gecwhiz
I have a 2002 Jimny Special and the remote has been a little unreliable so I decided to change the battery.
The old battery is CR1616 and still registers 3v
The new battery is DL/CR1616 by Duracell and does not work. It registers 3.3v
The new battery is said to be the replacement for CR1616, but it is lithium and of course the voltage is slightly higher.
I ended up replacing the old battery and the fob worked.
I have contacted Duracell in case their battery is faulty and whilst giving a more than adequate voltage, may not generate sufficient current (unlikely)
So my question is "Does the remote key fob have a voltage limiting circuit in it to prevent damage if the battery is over 3v?
And my second question is "What do I do for a replacement battery if all CR1616's are replaced with so called "equivalent" lithium cells
Help!
Help!
- TheHillsAreAliveWithTheSoundOfSheep
31 Mar 2022 16:03 #242639
by TheHillsAreAliveWithTheSoundOfSheep
Replied by TheHillsAreAliveWithTheSoundOfSheep on topic Door remote fob - is it voltage sensitive?
I replaced my fob battery a while ago as it was hit n miss... used a Duracell DR/CL1616 3.3v and had no issues at all with it.
Can't answer the key circuit protection part but you may have just had a dud battery new out the packet... I've had it before with various sizes
- Thank you received: 1983
31 Mar 2022 16:26 #242641
Replied by Lambert on topic Door remote fob - is it voltage sensitive?
I'm getting a new battery for mine tomorrow, I'll let you know how I get on.
- Thank you received: 664
31 Mar 2022 21:29 #242647
Replied by DrRobin on topic Door remote fob - is it voltage sensitive?
A CR1616 is a lithium cell, at least as far as I know and a new good battery will measure over 3.0V, usually around 3.2V.
The remote won’t have a voltage limiter and 3.3V shouldn’t damage the key fob.
You are measuring open circuit voltage, so if the DL1616 has a high internal resistance it’s voltage will drop f the fob draws a high current. I did check the specs, it says 55mA, I would have thought that was plenty for the key fob.
Is the DL1616 exactly the same size, perhaps it has slightly different dimensions and is not making a good contact? Otherwise it looks like you Ishtar have a duff battery.
Robin
Robin
- gecwhiz
01 Apr 2022 08:37 #242652
by gecwhiz
Replied by gecwhiz on topic Door remote fob - is it voltage sensitive?
Many thanks for your helpful response. Duracell have refunded the cost but that is not really an answer. The fact that the fob does not have an over-voltage protection eliminates one possibility. The other is that the battery which is within date and was making good contact, was actually on its last legs and gave up when put into service. We shall see when I try another brand of CR1616,
01 Apr 2022 08:44 #242653
Mine is now in service, just a generic cr1616. I have fob range for days.
Time to create page: 0.187 seconds
