Back wheel bearing with ABS
17 Mar 2022 07:15 #242357 by safari
Good morningI have a jimny and need to change the back wheel bearing which is with abs which I do not use so I do not have the abs ring on the collar is it possible to use a standard collar instead of the long one pls
if u worry u die if u dont worry u still die so why worry
17 Mar 2022 14:50 #242364 by maverick
nope
Jalapeño, IISY?
22 Mar 2022 07:46 #242437 by safari
Replied by safari on topic Back wheel bearing with ABS
taught so tks and if i remove the ring collar would it be safe to refit the same collar ?
  • X8GGY
22 Mar 2022 15:10 - 22 Mar 2022 15:19 #242444 by X8GGY
Replied by X8GGY on topic Back wheel bearing with ABS
I very much doubt you’ll be able to “remove” it?!
Theyre generally cut off…
Here’s a link to the BigJimny WiKi -
www.bigjimny.com/mediawiki/index.php/Rea..._bearing_replacement
step 20…
Dave
Last edit: 22 Mar 2022 15:19 by X8GGY.
23 Mar 2022 12:16 #242464 by Roger Fairclough
You can remove it by using a suitable puller but it is not recommended that you reuse it. The ring collar is what keeps the bearing in place so it's critical.
Roger
24 Mar 2022 09:14 #242467 by safari
a friend of mine told me he removed it with heat and refitted it with heat again next week i am going to his shop and see how it is done and if it is safe to refit
tks to everyone for the help
Time to create page: 0.239 seconds
