Oil Leak back of Engine - Cam sensor? What is the Cause?
17 Jan 2022 12:04 #241258
by Derksen
Oil Leak back of Engine - Cam sensor? What is the Cause? was created by Derksen
Hi everyone!
Today I noticed a few drops of oil on the floor of my garage, so I checked the underside of the engine for any oil leaks...and I found some. Please check the pictures for the whole overview. So I traced the 'main' oil leaks to two places: What I assume to be the Cam sensor and another place which I don't recognize.
Coolant fluid also seems to be leaking out from under the cam sensor or roughly that area, mixing in with the oil and forming small puddles in the nooks and crannies on top of the gearbox.
Now when I reverse into my garage, I drive over a little bump which rocks the whole car and I suspect that the coolant-oil mixture spills over at that time and slowly drips down the gearbox onto the floor, hence the oil stain on the floor.
My question, could you help me identify the origin of these oil leaks (maybe the Cam sensor and some other parts) and give me an indication of the urgency in replacing these parts?
Thanks in advance!
Hilmar
Thanks in advance!
Hilmar
18 Jan 2022 16:50 - 18 Jan 2022 16:52 #241286
by Scimike
Replied by Scimike on topic Oil Leak back of Engine - Cam sensor? What is the Cause?
It can be difficult to locate the source of an oil leak that’s been present for some time, its surprising just how far a little oil can travel.
Firstly, I don’t think you need to panic, so long as your vehicle is not losing a vast amount, the odd drip on the floor nothing at requires immediate action.
I can’t suggest a particular source for the leak in any certainty, anything with a gasket or O-ring around this area could be the cause.
My first action would be to clean the area or engine with de-greaser and dry it, then wipe around any suspect items with paper tissue until they are clean. Then run the engine, let it cool and wipe around again. The paper tissue will highlight very quickly any new sources of oil or coolant, start high on the engine and work your way down until you find the leak.
The only other way is to start changing gaskets and O-rings until it stops. As I said you don’t need to panic over the odd drip.
As a Land Rover owner multiple drips are classed as “oil tight”, Exxon Veldez slick is normal.
Last edit: 18 Jan 2022 16:52 by Scimike.
20 Jan 2022 18:54 #241323
Replied by yakuza on topic Oil Leak back of Engine - Cam sensor? What is the Cause?
Typical G13 leak. been leaking there since 1985
My SJ413's all leaked there where the distributor was and now the more recent g13's, the cam sensor. Cheap O-ring from Suzuki will fix.
Also just to dismantle and put silicone gasket compound could also do the trick, did that to a G16 i swapped on a mates Jimny.
