[solved] Jimny P0134 + P0172 Faults
21 Oct 2021 18:00 - 21 Oct 2021 18:00 #239555 by avehbiaslanturk
Hello everyone,
I have 2009 Suzuki Jimny at 140.000 km (M13A). 3-4 days ago, the engine check light appaered. I scanned with elm327. The faults are P0134 (o2 sensor 1) and P0172(System is too reach).
Today, local  serviceman replaced the O2 sensor and cleared the faults. After 3-4 km later, the engine check light appeared again. I scanned and saw that first P0172 fault appered, and after that P0134 appered again. And i realized that 02 sensor1 voltage value changes too much between 0.2-0.8  but sensor2's voltage value stands still.
-> There is no any performance issue
-> There is no exhaust leakage
-> There is no black smoke
-> Idle is fine
I wonder, that could be because of air filter? In the last maintenance, i have not replaced the air filter. Because it is only 3.000 km and looking clear. Or what else should we look at ?Thank you everyone...
Last edit: 21 Oct 2021 18:00 by avehbiaslanturk.
22 Oct 2021 03:19 - 22 Oct 2021 03:24 #239558 by Lambert
Replied by Lambert on topic Jimny P0134 + P0172 Faults
Do you know if the replacement sensor was a genuine parts item or an after market compatible one? There seems to be a few people experiencing issues with after market o2 sensors.
And if you took it to a professional workshop and then you are getting the same fault that they are supposed to have fixed, it needs to go back and they need to deal with it either under the parts warranty or their labour warranty.
Last edit: 22 Oct 2021 03:24 by Lambert.
The following user(s) said Thank You: avehbiaslanturk
22 Oct 2021 11:37 #239560 by avehbiaslanturk
Firstly, thank you Lambert. I supplied the sensor. As you said, yes it was a cheap sensor, not original. But good news is; P0134 fault has dissappeared, i only have P0172 fault. So i guess that my new O2 sensor is working properly. Sadly, there is no opportunity to take it a professional workshop in my City. Hope we can find the error.
22 Oct 2021 13:42 #239561 by DrRobin
Replied by DrRobin on topic Jimny P0134 + P0172 Faults
The ECU uses O2 Sensor 1 to adjust the fuel/air mixture (rich/lean) to the correct ratio, but can only adjust the setting so far.
The P0172 code is saying that the ECU has adjusted the mixture as far as it can and it is still showing as rich. Is the O2 sensor you bought designed for your vehicle, they output of these vary quite a bit so it might not be compatible.
I had O2 sensor problems on my other car, eventually I found that you have to remove the battery for 10 minutes to clear the long term fuel trim and let it go back to the default map when changing an O2 sensor.
If it is not a faulty O2 sensor or one that is not compatible with your vehicle, then the fault lies elsewhere.
The MAF sensor could be dirty, over-stating the amount of air entering the system;
If your air filter is clogged and reduced air flow that might give a very rich indication, but you should get poor performance as well, might be worth checking the filter;
A fuel injector may be leaking, putting too much fuel in to the system, or another fuel related issue;
You might have a vacuum leak;
You might have an ignition problem (spark plug/coil) which means that fuel is not buring correctly or timing.
If your engine runs fine with no black smoke, is there a petrol smell at the exhaust? You could take the plugs out to see if they look normal, or soot/oil?
If no petrol smell, plugs look fine, performance and MPG are all fine then most likely it is the MAF sensor over-stating the air flow, so actually everything is normal, but the car doesn't think it is or you have a vacuum leak.
Robin
23 Oct 2021 17:41 #239579 by avehbiaslanturk
Thank you Robin,
As you said, yesterday we cleared the air filter and MAF sensor and deleted the fault again. After that I went for a drive on mountain roads about 25-30 km. Thank goodness the fault light hasn't come on yet. I hope I never see it again :)
04 Nov 2021 09:24 #239853 by avehbiaslanturk
Unfortunately, the malfunction light has reappeared (P0172). But i think it's because of the air filter or MAF sensor. Becasue after cleaning the air filter and maf sensor, the malfunction light hasn't appeared for a long time. Normally it reappeared within 5-10 km after cleaning the fault. Also i reliazed that there is a smell of unburnt fuel in the exhaust when P0172 appeare.
Time to create page: 0.234 seconds
