Re:Spotlight interior switch - where to connect ground?
- Matt H-E
29 Sep 2021 11:09 #238994
by Matt H-E
Spotlight interior switch - where to connect ground? was created by Matt H-E
Hi All,
I fitted my KC Highlighters on the new(ish) Jimny, using the DirtyDogz diagram (which works perfectly, thanks DD):
I used the main beam wire (the single one on the right of the off-side main bulb connector, red wire with grey bands) and wired it via a 3-pin illuminated dash switch similar to:
But, and here's the question....as soon as I connect the 'ground' to any earthing point the light on the switch is permanently illuminated, not just when the spotlights are activated...so, where should the ground be wired to, and have I used the wrong wire from the headlight?
The spots work fine without the ground (only on with main beam when the dash switch is 'on'), it just doesn't have that 'on' light.
Any help most appreciated.
Mattzuki
Mattzuki
- Thank you received: 679
29 Sep 2021 11:54 #238995
Replied by DrRobin on topic Spotlight interior switch - where to connect ground?
The switch will link ACC and Power pins when closed and open circuit when off. From this point of view it doesn't matter which you wire to 12V and which you wire to the spot lamps, it still switches on and off.
The switch also has a bulb in it, between the switched power and ground.
If the switch bulb is always on it sounds like you have the +12V and spotlight power swapped over.
My guess would be that the switch bulb is wired to Power pin, therefore +12V goes to ACC and the spotlights go to Power terminal. Ground goes to ground. Then the switch bulb should come on when the spotlights are on.
Robin
Robin
- lookonimages
- Thank you received: 72
29 Sep 2021 12:36 - 29 Sep 2021 12:49 #238997
by lookonimages
Replied by lookonimages on topic Re:Spotlight interior switch - where to connect ground?
Suzuki has negative switching that is opposite to what most other vehicles are.
See this post.
www.4x4community.co.za/forum/showthread....cting-Spots-to-Jimny
There is word doc for wiring diagrams for both positive and negative switching
Suzuki is Negative. Use green one on the doc
Or the ironman wiring diagram.
See this post.
Last edit: 29 Sep 2021 12:49 by lookonimages.
29 Sep 2021 13:43 #239000
Replied by DrRobin on topic Re:Spotlight interior switch - where to connect ground?
The Ironman drawing (negative switching) is different to the DirtyDogz drawing (positive switching), so if you have wired it as per the DirtyDogz then according to the DirtyDogz drawing the switch connects as follows:
Switch Power - To red on back of headlight
Switch ACC - To Pin 85 Trigger (on relay)
Switch Ground - To Ping 86/30 (on relay) and live (Battery or other 12V)
The Ironman is as follows:
Switch Power - To red on back of headlight (Positive)
Switch Ground - To Ping 86 and black on back of headlight (Negative)
If you have wired your relay as per DirtyDogz, then I would wire the switch as per that as well, otherwise re-wire as per the Ironman drawing.
- Matt H-E
02 Oct 2021 10:31 #239070
by Matt H-E
Replied by Matt H-E on topic Re:Spotlight interior switch - where to connect ground?
Thanks for all the replies. I'll see what works.
Cheers
Matt
Cheers
Matt
Time to create page: 0.104 seconds
