Re:Re:Re:Re:ARB Vs Ironman Bullbar for 4th Gen (2021) Jimny
- LMcRae
14 Sep 2021 05:37 #238586
by LMcRae
Replied by LMcRae on topic Re:ARB Vs Ironman Bullbar for 4th Gen (2021) Jimny
Thanks mate! So in total the Ironman bullbar is 61.3kg compared to 45kg for the ARB bullbar? That's a big difference! Or does the 10.8kg winch mount weight only get added to the Ironman bullbar if am getting a winch?
- lookonimages
- Thank you received: 72
14 Sep 2021 06:26 - 14 Sep 2021 06:39 #238587
by lookonimages
Replied by lookonimages on topic Re:Re:ARB Vs Ironman Bullbar for 4th Gen (2021) Jimny
Edit.
Just spoke with ironman agents.
Yes the lux (3 loop one) is indeed a whopping 63kg
The special (1 very small loop) is 60kg.
That is heavy....!!!! For a jimny. !!
Last edit: 14 Sep 2021 06:39 by lookonimages.
- LMcRae
14 Sep 2021 11:52 #238595
by LMcRae
Replied by LMcRae on topic Re:Re:ARB Vs Ironman Bullbar for 4th Gen (2021) Jimny
Thanks a lot for clarifying mate. I'll definitely be going with the ARB and saving nearly 20kg in weight.
14 Sep 2021 12:58 #238601
by 300bhpton
Replied by 300bhpton on topic Re:Re:ARB Vs Ironman Bullbar for 4th Gen (2021) Jimny
I'd be amazed if the all up weight differs much between them. You'd need to know what the ARB figure actually includes.
- LMcRae
15 Sep 2021 02:10 #238617
by LMcRae
I contacted ARB and they said they put 45kg on the vehicle and they will take off 8kg so there is actually only a net gain of 37kg for the ARB bulbar. I'm assuming there will also be approximately 8kg taken off the vehicle to put the Ironman bulbar on as well.
It does seem strange that the Ironman bullbar weighs so much more than the ARB but that's what all the figures/sources are saying...
15 Sep 2021 08:55 #238628
by 300bhpton
Well I'm not really disputing the figures. Just trying to understand what they are.
If the Iron man figures include 9.2kg for fixings (I assume nuts & bolts). The ARB item bolts on in the same way to the same places. So would also need a similar amount of fixings.
Meaning the ARB figure either includes or excludes this. If they include, 35kg suddenly seems very lightweight/light duty for the bumper compared to the Ironman. Or 55kg suddenly seems very similar. On a similar note, they both support winches, which is just a tray that bolts between the chassis rails. I'd suspect they are very similar for each.
I imagine the only thing that could make a difference would be the gauge of the steel used. If one bumper is more heavy duty than the other.
Time to create page: 0.907 seconds
