Engine conversion from m13a to an auto Liana m16a flywheel wont fit.
  • jeremyrfk
27 Aug 2021 00:57 - 27 Aug 2021 00:58 #237917 by jeremyrfk
Converting a 2001 jimny m13a to an m16a from a 2002 automatic liana and found the m13a flywheel won't bolt onto the m16a. Anyone done this conversion and how'd you get around it? Cheers.
Last edit: 27 Aug 2021 00:58 by jeremyrfk. Reason: Add Icon
28 Aug 2021 08:37 #237946 by Keithy
Any pictures of the crank and drive plate also the flywheel.......I put a manual M16 into an auto jimny with no issue.
28 Aug 2021 09:27 #237948 by j999pre
Make sure you remove the spacer from the end of the crank
Grey pick up Jimny
  • jeremyrfk
30 Aug 2021 05:20 #238006 by jeremyrfk
That was it! Thanks mate
  • Dirtbird
30 Aug 2021 20:50 #238035 by Dirtbird
Mad your sorted
09 Nov 2021 08:10 - 09 Nov 2021 09:51 #239958 by Dured
Encountered similar problem while trying to fit Jimny M13A Automatic flywheel on to a Liana M16A (both non VVT) ex-manual engine, but the center bore diameter seemed to be larger on the Jimny flywheel.
But I can confirm there is a flange on the engine crankshaft for those with automatic gearbox, which is not present for manuals with thicker flywheel! So take the flange off m13 auto and use it on the m16 engines crankshaft together with the m13 automatic flywheel!
Last edit: 09 Nov 2021 09:51 by Dured.
Time to create page: 0.323 seconds
