need some advice
- FIRSTJIMNY
29 Nov 2010 19:34 #6787
by FIRSTJIMNY
need some advice was created by FIRSTJIMNY
I have a 2001 Jimny. The only modifications are Dobinson's shocks and springs for a 2 inch lift, ARB winch bumper w/T-Max 9500 lb. winch and LightForce Lance 140 lights.
with only a certain amount of money to spend what would get the best results:
front and rear ARB air lockers with stock gearing or swap to a Samurai t-case with 4:16 gears?
Need some advice from someone more experience in 4x4 than myself. Thanks.
- adamjimny
30 Nov 2010 06:29 #6799
by adamjimny
Replied by adamjimny on topic Re: need some advice
id go for the gearing mod as you will have so much more control on the rough stuff meaning less clutch slipping needed
- darthloachie
30 Nov 2010 07:50 #6802
by darthloachie
Replied by darthloachie on topic Re: need some advice
I'd go for the transfer box first, then a rear diff lock don't rush into a front one
I have a front Arb but can only use it if the climb etc is straight as if you steer you break a half shaft
- adamjimny
30 Nov 2010 08:21 #6805
by adamjimny
exactly my thought go for the more control option then extras afterwards
30 Nov 2010 18:28 #6838
by kirkynut
What he said. The gearing is too high in low box and becomes an issue.
Replied by kirkynut on topic Re: need some advice
adamjimny wrote: id go for the gearing mod as you will have so much more control on the rough stuff meaning less clutch slipping needed
Time to create page: 0.549 seconds
