Fitting a Turbo or Supercharger to Gen4
07 Oct 2023 20:12 #251250
by 300bhpton
Replied by 300bhpton on topic Fitting a Turbo or Supercharger to Gen4
Not wanting to disagree, but I find that unbelievable. Plenty of extreme modded vehicles about. And I really don't think an insurance company insuring modded cars would give two hoots if it was an engine swap, turbo, supercharger or a combo of all three.I understand Twisted considered fitting a supercharger but were unable to find an insurance company in the UK that would insure the modified vehicle. That's why they have gone down the turbo route.
- rogerzilla
07 Oct 2023 20:20 #251251
by rogerzilla
Replied by rogerzilla on topic Fitting a Turbo or Supercharger to Gen4
Are they changing the crank? The problem with adding any kind of forced induction is detonation, so the engine has to run rather rich when on boost* unless you drop the compression ratio. Super unleaded helps.
*which is why turbo cars used to do well in the NEDC fuel economy tests but appallingly in the real world - NEDC had such slow acceleration that the turbos never really spooled up.
07 Oct 2023 22:07 - 08 Oct 2023 09:09 #251252
by lightning
Replied by lightning on topic Fitting a Turbo or Supercharger to Gen4
The Wrangler does weigh more, but not massively so. And certainly not over the rear wheels, as they are front engine. The YJ Wrangler (launched in 1986) weighed in at 1,295–1,470 kg. So much closer to the Jimny and could still be had with the 170hp 4.0 litre engine.Also the Wrangler is quite heavy so has plenty of weight over the rear wheels. The Jimny only weighs as much as a packet of crisps.
Best of luck controlling 150bhp through the back wheels on a Jimny in the rain.
I really can't see 150hp from a 1.5 litre forced induction being all that much trouble in a Jimny. Dry or wet. (QUOTE)
But the Wrangler is full time 4wd
l keep saying it...the Jimny is RWD only on the road.
Our 2020 Jimny struggles with the standard 100bhp in the wet, with 150bhp and more torque it would be a death trap.
Better tyres might help, but best of luck driving a supercharged Jimny on a damp, leafy road.
Plant your toe, wait for the turbo to kick in, and hope you can keep the Jimny on the road
Last edit: 08 Oct 2023 09:09 by lightning.
07 Oct 2023 22:41 #251253
by Busta
Replied by Busta on topic Fitting a Turbo or Supercharger to Gen4
Some interesting comments here!
You can insure a supercharged car just as easily as a turbocharged one.
You don't need to change the crank when you fit a turbocharger.
You won't die driving a 150hp Jimny. The throttle isn't an on-off switch.
- Thank you received: 1984
08 Oct 2023 04:04 #251254
Replied by Lambert on topic Fitting a Turbo or Supercharger to Gen4
Agreed. And don't forget things like the ariel nomad or the rzr turbo they are lighter if not slightly smaller than the jimny but they are double or triple the power output and have similar capability off road. It's also worth noting that you would be going into ownership of a modified jimny knowing that it is modified and therefore it wouldn't be unreasonable for you to use some decorum until you became familiar with it. It's why 911 turbos come with a training course if you are not a repeat customer.
08 Oct 2023 08:41 #251256
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic Fitting a Turbo or Supercharger to Gen4
In the car wow video Matt was struggling with the traction control kicking in although he was blaming the tires rather than the turbo. I still think it’s an accident waiting to happen if you don’t know how to handle a Jimny on the road.
2018 JB43 SZ4
2023 JB74 LCV
Time to create page: 0.277 seconds
