Unable to change gears after 2" lift and 30" wheels upgrade
14 Jun 2021 06:16 #235777
Replied by yakuza on topic Unable to change gears after 2" lift and 30" wheels upgrade
Clutch pedal bracket?
www.bigjimny.com/index.php/forum/7-jimny...h-cable-twisted-torn
Or hard worn clutch cable.
- olgv
30 Jun 2021 22:38 - 30 Jun 2021 22:39 #236271
by olgv
Replied by olgv on topic Unable to change gears after 2" lift and 30" wheels upgrade
The enigma just got solved
What is basically happening is that the clutch cable's filet, where gets adjusted in the engine mount, has worn out.
Basically the worn fillet makes it looser or harder, at that tipping point that sometimes allows for the gear to shift or does not.
Giving it couple of turns temporary fixed the issue. After testing for 1 week and all good I changed it all together and everything is butter smooth.
For sure it is not related to the lift.. unless the guys at the garage hammered the clutch bracket accidentally somehow and damage the fillet, or who knows. Anyhow, don't want to blame anyone, just happy that it got sorted and I have a new clutch cable
Thank you very much guys for all the pointers.
Last edit: 30 Jun 2021 22:39 by olgv.
Time to create page: 0.130 seconds
