Re:Re:Fuel lines
  • mickt
02 Jun 2021 10:29 #235543 by mickt
Replied by mickt on topic Re:Re:Fuel lines
OK then how much for the 8?
02 Jun 2021 14:20 #235550 by mlines
Replied by mlines on topic Re:Re:Fuel lines
There are three different mounts spread along the chassis
One is clearly not the one you want as it does not have many pipe positions on it
The other two mounts are:
£6.17 each or
£4.46 each depending on which you want.
  • mickt
07 Jun 2021 10:04 #235644 by mickt
Any luck with these mounts/ Also I am after the exhaust bolts that connect the front exhaust to the middle exhaust pipes if possible.
07 Jun 2021 10:15 #235645 by mlines
Did you choose which mount you wanted from the picture I sent?
  • mickt
07 Jun 2021 10:23 #235646 by mickt
I mentioned that the two three pipe mounts are for the front part as the pipes rise into the engine bay. The other 6 consist of four mounted vertically to the chassis rail and two horizontally floating as it were in the awkward channels. These are the five pipe ones The pictures I found difficult to interperate.
