Rattle sound going in-between 3.5 k and 4k RPM
18 May 2021 12:51 #235176 by DrRobin
When the engine is under load it will move slightly on it's mounts, especially when accelerating, that might be enough for something to touch on the exhaust system and cause the rattle, which is not there when the vehicle is not moving.
It could also be that the prop shaft needs to turn to get the sound. The answer will be the same something loose.
  • sunyboy
01 Jun 2021 21:08 #235534 by sunyboy
hi did you find out what rattle was ive same problem on a 2014 jimny mostly between 50 and 60 mph and when going up a hill slight rattle any help be grate thanks
  • Jimnycv
30 Sep 2021 20:55 - 30 Sep 2021 20:56 #239020 by Jimnycv
Hello, fellow Jimny owners,
I am having a similar problem with a 2019 Jimny, except here the rattle comes in at 1.5k - 1,75k RPM. After a couple of months, I recently tracked it down to the engine area but can't pinpoint where it is happening. Could someone with a bit of mechanics knowledge point me where to look?
The car was exported from Europe to Cape Verde, where there are no Suzuki dealers, so the guarantee is of no use.
In the video below you can hear the sound come in at the 18 second mark.
Thanks a lot
Last edit: 30 Sep 2021 20:56 by Jimnycv. Reason: video did not upload
01 Oct 2021 05:16 #239025 by Lambert
That sounds like an exhaust heat shield to me.
01 Oct 2021 07:18 #239029 by Soeley
Really hard to tell from a video, might be worth investing in a mechanics stethoscope and start probing different areas of the engine to locate the noise.
01 Oct 2021 08:08 #239037 by lookonimages
Lambert wrote: That sounds like an exhaust heat shield to me.
I am with Lambert on this one. It sure sound like metal vibration that is introduced at a certain RPM.
But it can be anything. Do you have access to workshop pit so you can get under engine to see if you can spot something from underside.
Time to create page: 0.344 seconds
