ABS pump bleed
10 Apr 2021 20:37 #234384
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic ABS pump bleed
Excellent. Thanks. Very much Dr. Robin.
I know it's not the same unit, but I think I might just buy the pro version. I can always return it if it doesn't have the functionality. If it talks to and resets the abs, hopefully it should bleed the pump.
10 Apr 2021 20:39 #234386
by Mike G
Lambert,
My jimny has been sitting empty for months and I've done nothing to prevent the brake fluid from leaking out. I just dont want to take the chance of having spongey brakes when I most need them. Plus I do like a new gadget.
11 Apr 2021 08:02 - 11 Apr 2021 08:04 #234389
by Mike G
Ok,
So on further inspection, with a budget based hat on and thinking about what I actually need the tool for (which is to bleed the ABS pump only), there is a cheaper option at (present) for £50.
Autel AP200C
The AP200C seems to have the ABS bleeding functionality, so I've bought one of them, should arrive in a week or so. I think it will reset ABS up to a year of activation, after that I believe you have to pay a subscription fee, however, the likelyhood that I'll be doing anything with it again is low.
There are two other versions of this product the AP200H and AP200M, but these don't have the ABS function and also you can only use them on one manufacturer brand per license, as far as I can make out.
I'll let you all know how I get on with it.
Autel AP200C
Last edit: 11 Apr 2021 08:04 by Mike G.
- Thank you received: 673
11 Apr 2021 08:50 #234391
Replied by DrRobin on topic ABS pump bleed
The Autel dongle looks pretty good, things must have moved on since I bought my Autel (last year), I didn’t see this model so perhaps it wasn’t sold then.
By not having a display and keyboard it makes it a lot cheaper to produce, but should just work the same and as you say it mentions ABS bleed.
Robin
Robin
11 Apr 2021 09:17 - 11 Apr 2021 09:19 #234392
by Mike G
I went down the rabbit hole of youtube OBDII reader recommendations and ended up finding it, otherwise I'd have never seen it. I would have prefered a physical device like yours as I don't trust the longevity of app support due to the ever changing hardware platform and app stores hosting apps are never a guarantee, even if they are paid. But as it's not something I'll use a lot and as long as I keep the phone that I know it works on, it should work in the future. On the plus side, it does make it easier to update.
£50 was the hook for me. I've seen them at around £80. But I might have still went for the pro at that price. The reason I didn't go for the model you had was that it doesn't appear to have the brake bleed capability (as far as I could tell without using it). But I might find that the one I get doesn't bleed the ABS on the jimny, however, time will tell and I'll post an update once I know for sure.
Last edit: 11 Apr 2021 09:19 by Mike G.
11 Apr 2021 10:35 #234396
Just tested my Maxi Link on my Gen 3, it scanned for the protocol and then correctly connected using KWP 2000 and read all of the fault codes as well as live data.
Mine doesn’t have the ABS bleed function so if it works on your dongle that is a definite plus.
I have no doubt that your dongle and software will work just fine.
