2006 Jimny Clutch Release Bearing
26 Mar 2021 16:09 - 26 Mar 2021 16:11 #234045
by Davemc
2006 Jimny Clutch Release Bearing was created by Davemc
Good afternoon. I'm a newbie. We bought a 2006 Jimny last year with 83k on the clock last year. There is a ticking/vibrating noise coming from the clutch when the clutch pedal is out. When it's depressed it disappears. I've had a look through the clutch cable aperture and can see the release bearing rattling and causing the noise. If I adjust the clutch cable to give more slack it rattles more and it's a bit harder to get it into gear - it looks loose like it's not attached to the clutch fork properly. If I tighten it up the slack on the cable, it pulls the bearing near to the clutch pressure plate and makes it a bit quiter but then it still vibrates presumably because it's turning all the time. In theory, the gearbox was reconditioned and a new clutch fitted when we bought the car. The clutch pressure plate does look new but I'm wondering if they've fitted the wrong release bearing or it's not clipped in correctly.
Question is:- should our car M13A car have either or both clips in the attached diagram (6 or
, I can't see a No.6 clip through the aperture.
Phot also attached hopefully.
Thanks for any help.
Dave
Dave
Last edit: 26 Mar 2021 16:11 by Davemc.
- Roger Fairclough
- Thank you received: 225
26 Mar 2021 19:54 #234049
by Roger Fairclough
Replied by Roger Fairclough on topic 2006 Jimny Clutch Release Bearing
Welcome to the forum.
Did you get a warranty with the car and if so, does it include the clutch? If it does your first stop is to talk to the seller.
Please come back to us with an update.
Roger
Roger
26 Mar 2021 20:29 - 26 Mar 2021 20:35 #234051
by Scimike
Replied by Scimike on topic 2006 Jimny Clutch Release Bearing
Hi,
Not changed the clutch on our Jimmy, but the WIKI ^^^^^^has a write up on changing the clutch and I can only see part 6, but the other bit does not apear to have any function relating to holding the release bearing. It's possible it's behind the release arm in this photo, something could be behind the arm, sort of clip showing in the upper aperture. The dome in the metal just above this matches the dome shape of the top of part 8..
www.bigjimny.com/mediawiki/index.php/Fil..._release_bearing.png
Last edit: 26 Mar 2021 20:35 by Scimike.
- gsalini
26 Mar 2021 20:44 #234052
by gsalini
Replied by gsalini on topic 2006 Jimny Clutch Release Bearing
Hi there,
I have changed the clutch myself on the jimny. Both 6 and 8 should be there, no doubt about it. 6 holds the bearing in place to the fork and 8 holds the fork in place on the gearbox.
Its a bit of a pig of a job to get the gearbox off but doable.
27 Mar 2021 09:58 #234065
by Davemc
Replied by Davemc on topic 2006 Jimny Clutch Release Bearing
Thanks very much for the replies.@ Roger. We have a very thin guarantee that covers parts only and specifies that they must suddenly fail mechanically. The gearbox has an oil leak from the drain and fill plugs and possibly from the top so presumably no thread sealer was used, so I’m not 100% confident in the garage anyway. I had a different local garage look at it to see if they fancied the job, or at least to confirm what I think. They diagnosed a problem with the bell housing – see pic below. I’m still lost as to why – just makes me more cynical and want to do it myself.@Scimike. Yeah I’ve read the clutch replacement guide and thought the same about the springs. I’ve found another guide that suggests that the clutch can be removed without taking the gearbox out.
pmmonline.co.uk/technical/how-to-replace...h-on-a-suzuki-jimny/
The Wiki guide also mentions that some people have managed to change the clutch at the point of moving the gearbox back. So I’m thinking of attempting that – it looks like that may be enough room for me to at least have a look and take off the clutch fork.@ gsalini. Thanks for confirming – can I ask what year yours is? I read the topic below and thought one of the clips may not be used on a later Jimnys but I wasn’t sure which clip.
www.bigjimny.com/index.php/forum/7-jimny...clutch-return-spring
I was hoping to get the clips and a release bearing before starting the job. I can see clip 8 for sale in various places but not clip 6 – the nearest I can see is something off a Suzuki Carry Van. It does look tricky but I think I’ll give it a go. I like to think I’m slow but thorough. This is my daughter’s first car – tried to talk her into getting a sensible car but I’ve got a TVR so could not argue. It does mean I’m used to a bit of frustration, getting stuck and leaving something for a week J.Thanks again for the replies. Forums like this are great for sharing knowledge. Posts must be read by 100s lurking in the background as well as those who take the time to reply. I’ve just changed the alternator and PAS belts. The air conditioning doesn’t work (pump rusted) so I’ve already used a tip to bypass the air conditioning pump until I get round to looking at it.Dave
27 Mar 2021 10:00 #234066
by Davemc
Wil try to format better next time.
Time to create page: 0.259 seconds
