Re:Re:2012 Jimny Gearbox
25 Feb 2021 18:05 #233264 by Stefan
2012 Jimny Gearbox was created by Stefan
Hi everyone. So I got another question for you guys.
My Jimny has a gear whine, whenever I drive, so this made me wonder whether the 2012 model perhaps had a gearbox with straight gears, as the are noisier than the modern gearboxes with bevell gears. Does it have straight gears? Or may there be a cause to this whine? I changed all the diff oils, except the gearbox ane transfer case as the transfer case had sufficient oil and gearbox was to hard to reach the plug and I don't know how I'll fill it back up in that stupidly small space.
Anyone that can help me please? Shed some light on the situation for me?
Thanks again,
Stefan
25 Feb 2021 18:24 #233265 by Lambert
Replied by Lambert on topic 2012 Jimny Gearbox
Is there any particular gear that is noisy more than the others? As to replacing the gearbox oil with a little perseverance it's possible if messy to refill with the spout on one of the 1 litre bottles but it's definitely a faff.
25 Feb 2021 18:42 #233266 by Roger Fairclough
Replied by Roger Fairclough on topic 2012 Jimny Gearbox
To my knowledge, the only straight cut gears you will find are for reverse.
Roger
25 Feb 2021 18:58 #233268 by Busta
Replied by Busta on topic 2012 Jimny Gearbox
I'm not entirely sure when the last production car with straight cut gears was sold, but I'd wager it was about 60 years before 2012. Chances are your gearbox is failing as many around that age do. There is information about R72  gearbox failure in the Wiki.
25 Feb 2021 18:58 #233269 by Scimike
Replied by Scimike on topic 2012 Jimny Gearbox
I suspect nothing is wrong with it, they do have a more noticeable gear noise than a "normal car". Plenty of gears in motion below so is to be expected.
A work colleague got in mine and commented it sounded like straight cut gears, he's into performance "sleepers", so he should know!
It's actually very quiet, but I do understand his comments in the lower gears.
I quite like it - makes travel slow sound fast
25 Feb 2021 19:42 - 25 Feb 2021 19:42 #233270 by Roger Fairclough
Some early Ferrari g/boxes used grease as the lubricant. Maybe they had straight cut gears!
Roger
Last edit: 25 Feb 2021 19:42 by Roger Fairclough.
Time to create page: 0.365 seconds
