Fuel Pump Removal G13BB Jimny 1999 JLX
- Owl
20 Feb 2021 08:44 #233027
by Owl
Replied by Owl on topic Fuel Pump Removal G13BB Jimny 1999 JLX
Just read the fuel pump guide, with regards to fuel pump installation, a new gasket required plus they say a new cover plate. Is it a must do, to replace that cover? I havent removed it as yet, assuming its thin steel plate moulded cover? Ive done a couple of other makes of cars and recognise there was a metal plate cover but it wasnt necessary to replace those?
Just wondering what others have done in this situation, replace fuel pump cover or reuse the existing one? Because the access is pathetic, probably a bit of insurance to replace the cover as well!? Owl
- Owl
20 Feb 2021 08:47 #233028
by Owl
Replied by Owl on topic Re:Fuel Pump Removal G13BB Jimny 1999 JLX
Wheel arch cover, Ill go see Owl.
20 Feb 2021 10:12 #233031
by Old Neil
Replied by Old Neil on topic Re:Re:Fuel Pump Removal G13BB Jimny 1999 JLX
Right hand rear wheel arch there is a plastic access cover i found it useful support fuel tank with a Jack let tank down a little remove wheel then cover, easyer to release fuel lines etcOwl wrote: Wheel arch cover, Ill go see Owl.
20 Feb 2021 10:35 #233036
by Old Neil
- Owl
21 Feb 2021 04:48 #233061
by Owl
Replied by Owl on topic Re:Re:Fuel Pump Removal G13BB Jimny 1999 JLX
yes looks much the same, I have a R/H drive with fuel cap on the right side. Its not going to be easy i think, I'm dreading this.
22 Feb 2021 17:27 #233106
Replied by jackonlyjack on topic Re:Re:Fuel Pump Removal G13BB Jimny 1999 JLX
I would advise leave the filler/breather hoses in place and remove tank end
If you try to remove the 10mm head bolts from behind the filler flap
these will snap off
these will snap off
Time to create page: 0.717 seconds
