225/70/15 AT Tires?
  • justintime441
16 Nov 2020 02:33 #230075 by justintime441
225/70/15 AT Tires? was created by justintime441
Hello all, new guy to the forum with many questions,
Why does it seem like everyone is running either 205s, 215s or if youre brave 235s? What about 225s? Are there no all-terrain versions of that tire size? Seems like the 225s would be the best choice for my Jimny on a soon to be 4" lift.
Cheers :)
16 Nov 2020 05:01 #230077 by Lambert
Replied by Lambert on topic 225/70/15 AT Tires?
Welcome to the forum. You hit the nail on the head, it's not a particularly common off road pattern size.
The following user(s) said Thank You: justintime441
  • Groenewald
16 Nov 2020 05:28 - 16 Nov 2020 05:32 #230079 by Groenewald
Replied by Groenewald on topic 225/70/15 AT Tires?
Hi!
I have just gone through the tyre exercise.
I was also looking specifically for 225's but could not get any. So I got the 215/75/15 BF Goodrich K02's.
If you cant get 225s, dont worry too much. The stock tyres on mine were 195's. However they tapered, so the actual contact patch was even narrower. The 215s dont have that much of a taper and have a contact patch that is wider than the 20mm increase would suggest.
For tyre compatibility take a look at
www.bigjimny.com/mediawiki/index.php/Tyr...age_-_best_practices
Keep in mind:
Gen 3 Jimny.
Use the table as is. 205/70/15 is the factory standard
Gen 4 Jimny
195/80/15 is the standard. Check from there.
Last edit: 16 Nov 2020 05:32 by Groenewald.
16 Nov 2020 09:20 #230084 by jackonlyjack
Replied by jackonlyjack on topic 225/70/15 AT Tires?
I had 225/75/16 and was a nice fit
Then changed them for 195/80/16 extreme to suit my trialling needs
Now member sniper is putting the 225's to good use :)
16 Nov 2020 11:14 #230087 by 300bhpton
Replied by 300bhpton on topic 225/70/15 AT Tires?
justintime441 wrote: Hello all, new guy to the forum with many questions,
Cheers :)
Tyre sizes aren't just about width. They are about diameter and sidewall size too. Especially off road. In the UK I've found narrow tyres tend to work better than fat ones as a general trend.
  • Groenewald
16 Nov 2020 12:08 #230090 by Groenewald
Cheers :)
Aggressive narrow tyres give it that classic ww2 Willys Jeep look!!!
Time to create page: 0.221 seconds
