New Jimny - first mods?
  • Groenewald
07 Nov 2020 03:49 #229761 by Groenewald
Replied by Groenewald on topic New Jimny - first mods?
I have taken a look at the Gabriel shocks and springs kit: looks very nice!
50mm is a significant raise... I think this would be an ideal combination with new tyres.
How does it affect on road handling? Specifically rolling from side to side?
  • Andy2640
07 Nov 2020 07:58 #229768 by Andy2640
Replied by Andy2640 on topic New Jimny - first mods?
Groenewald wrote: Hi Guys,
I will hopefully be picking up my 2020 this afternoon.
It has the following: Towbar, Roof Rack.
What would be the best first mods from the ground up?
I am thinking about 32mm wheel spacers - does anyone have experience with these? It really looks like a good idea to give the car a bit of a bigger footprint.
Off set alloys or steelies will do the job nicely. And will not wear like the dreaded wheel spacers.
07 Nov 2020 09:23 - 07 Nov 2020 10:41 #229771 by lookonimages
Groenewald wrote: I have taken a look at the Gabriel shocks and springs kit: looks very nice!
It is Huge difference. Body roll reduced significantly yet road handling still enjoyable.
It is a little stiffer but really enjoyable. Seen today again the difference just in a very very strong cross winds. (You know CapeTown winds)
This is standard vs gabriels.
HDP same push in as stardard but much longer extention. Thus huge increase in wheel travel distance. The longer springs facilitate the longer shock extention.
On a gravel road they are exceptional.
The gen4 jimny is a very soft ride standard and me coming from a gen3, you notice the softer ride of gen4 immediately.
Gabriel safari HDP front item number GS56283
Compressed 280mm extended 450mm
Gabriel Safari HDP rear item number GS56284
Compressed 314mm extended 501mm
So fronts HDP will push in 10mm (280-290) more then std shocks, but extent 70 mm longer (450-380) then std shocks.
So the rear HDP will push in 14mm less (314-300) then std shocks, but extent 51 mm longer (501-450) than std stock
NEVER FIT JUST THE Gabriels on its own. HAVE TO BE with a spacer kit or a longer spring set.
Last edit: 07 Nov 2020 10:41 by lookonimages.
The following user(s) said Thank You: Groenewald
  • Groenewald
09 Nov 2020 08:02 #229846 by Groenewald
Hi Lookonimages,
Thanks for the info! I love reading technical stuff.
Apart from the suspension benefits I am very impressed with the side by side photo of the shocks.
In terms of suspension/tyres this will be my first mod.
Where did you have them installed? I can either do it at Suzuki or get someone out that we have been using to service our vehicles.
09 Nov 2020 08:58 #229849 by PNP
Replied by PNP on topic New Jimny - first mods?
One should research carefully all mods and always keep in mind what it is one wants from their Jimny:
the first and most immediate mod -> tyres; the bridgestone h/t are dangerous even on the black top. being an off roader in a country that is mountainous and with all terrains prevalent I chose the BFG KM3 215 75 r15, a/t don't cut it for my drive.
my biggest concern is weight, so i was and still am refraining from a roof rack and overloading, however i have installed Suzuki's under body protection prior to lifting, even though limited, meantime did my research and went with the ARB OME 40mm lift as it was customized for the JimnyJB74W. The next mod was a winch rather than lockers, as the AllGrip does a damn good job thus lowering the priority for lockers. The Jimny has not failed me yet in the varied rough terrains of Greece ; rocks, river crossings, mud, snow, sand, gravel and on Trans Alp European travel.
09 Nov 2020 12:09 #229861 by 300bhpton
Replied by 300bhpton on topic New Jimny - first mods?
If the offset wheels give the same offset as the spacers, you will get exactly the same results. The bearings will not know the difference.
Time to create page: 0.339 seconds
