locking hubs
  • mkay
28 Nov 2010 16:18 #6690 by mkay
locking hubs was created by mkay
are locking hubs and lock out hubs the same thing?
also is the jimny a front axle disconect system?
i ask with referance to these-
warn.iwebcat.com/_Members/lookups/partde...&hdnAPFlag=&hdnWN=1&
28 Nov 2010 17:34 #6703 by facade
Replied by facade on topic Re: locking hubs
No idea on the first question, very likely one is American English for the other though.
The Jimny is not a front axle disconnect system, these are fitted to Jeeps.
Basically, the longer driveshaft is split into 2 pieces with a vacuum actuator on the axle to slide a locking ring along to join them. In 2wd the diff stops turning and the unbroken driveshaft spins the little spider gears to wear them out.
Can't see why you can't use free wheel hubs with that system though, they are not necessary, but wouldn't hurt anything, in fact, I'd likely jam the actuator into lock and use freewheel hubs.
The following user(s) said Thank You: mkay
