Re:Lockers for the JB74
28 Jul 2020 19:39 #225804 by mlines
Replied by mlines on topic Re:Re:Lockers for the JB74
Assuming you mean the gears that transfer the power to the rear halfshafts.
Gen3 Jimny - Part Number: 27341-83000
Gen4 Jimny - Part Number: 27341-83000
This means they are the same, so have the same spline count. In fact all of the core components in the diff are the same.
I would also be suspicious that they quote the number a "TR208" as the classic locker for the Gen3 is the RD208, are they quoting you for a Gen3 locker? Mind you, I see that one UK supplier lists them as RD208Gen3 and RD208Gen4 so there might not be a lot of difference as you would have thought the number would have changed significantly
The following user(s) said Thank You: Boris Ekner
28 Jul 2020 19:51 #225805 by 300bhpton
I think there is an ATB available also for the rear. Jimnybits list one.
I think that is the way I’d be going. Enhances the traction control. Requires no user intervention. Works in all situations, including 2wd on road. And doesn’t reduce your turning circle.
But in the U.K. we have far less rock crawling style terrain.
  • Boris Ekner
29 Jul 2020 22:51 #225842 by Boris Ekner
Replied by Boris Ekner on topic Re:Re:Lockers for the JB74
mlines wrote: Assuming you mean the gears that transfer the power to the rear halfshafts.
Yes, I refer to the half shafts, as you call them.
Based on your answer this should mean that the progressive locker, i.e. Lokka and/or LockRight from Gen3 should fit just fine in the rear of Gen4, right?
Update from 4xFourArt.com:
The price is €200 + shipping.
PS
I will ask them if it is the same locker for the front axle as well.
I'll keep you posted.
Regards
..Boris
  • GrelloJimny
14 Jul 2021 08:16 #236675 by GrelloJimny
Replied by GrelloJimny on topic Re:Re:Lockers for the JB74
Hi, I similarly have been looking at ‘Lokka’ and ‘LockRight’ diff lockers, but they are all only for the Gen 3. Did you find out if the drive shafts & splines are the same on the Gen 3 and Gen 4?? If so they should fit on the Gen 4.
14 Jul 2021 20:27 #236686 by sniper
Replied by sniper on topic Lockers for the JB74
I drive a gen 3 with a Quaife ATB..... I think it's the best thing since sliced bread, you would have to drive it, to fully appreciate it. It alters the chassis dynamic in a big way.....
Have a read up on the way they interact with modern ABS traction systems.... Very clever and very effective from what I read.....
I am currently fitting a transfer case handbrake which will allow me to fit "fiddle" brakes on the rear wheels, allowing me to manually brake each rear wheel. If I brake a wheel that is spinning,  the ATB diff will transfer drive to the other wheel.... Doing manually, what the gen 4 does with its computers...
sniper
14 Jul 2021 20:56 #236687 by Roger Fairclough
If you have a Quaife ATB I do not understand why you want fiddle brakes as well. Surely the ATB will do it all for you.
Roger
Time to create page: 0.283 seconds
