Ignition coil help
- Thank you received: 2001
Thanks Lambert, I don't know technical side if the ECU can handle the extra load, just thought I'd ask, cheersLambert wrote: As far as I am aware no one has done this. Probably because the standard ecu won't support it. Unless someone knows different?
I know the injectors are individually controlled (at least in a m series they are)
Thanks RiccyRiccy wrote: I would doubt the standard ecu will have more than two coil drivers and how to modify the software i wouldn't know. Keithy is your man for coil-on-plug info as thats what hes using I believe...
I'm not clued up if the 4 separate coils would put a strain on standard ECU (ohms/voltage?)Sorry to be a pain
