G series to M series motor swap
12 Jul 2020 15:27 #224906
Thanks Lambert, but thats not strictly what I've done. My car is 2006, so a M series VVT shell/wiring/chassis (like Dreadnaught), but a M series non-VVT gearbox fitted to the vvt engine
I think @Old Neil is wanting to put a vvt M series engine into a G series car, thus the bell housing questions. Unfortunately that's where my knowledge runs out, having never fiddled with a G series engine/box.
Replied by Riccy on topic Re:G series to M series motor swap
Lambert wrote: If you have a look at the ulysses build by riccy in the build area he has done it. Amongst others.
12 Jul 2020 15:47 #224907
by Old Neil
Replied by Old Neil on topic Re:Re:G series to M series motor swap
Can't i put a r7me gearbox into my early jimny, is the later transfer case separate like my early jimny
12 Jul 2020 15:57 #224908
Yes, It'll fit exactly as the current gearbox does without needing to modify the rear bracket. Only difference, as far as I know, is the bell housing shape
Your G series chassis should have the same gearbox/engine rear mount and gearstick/transfer-box setup as the early m series chassis. Not sure about the intermediate prop, but would expect it to be the same.
Someone who has seen both chassis will tell you (g series and m series non vvt) :whistle:
Maybe @J999 pre would be worth a PM as he's seen and broken-for-spares a lot of Jimnys
Replied by Riccy on topic Re:Re:G series to M series motor swap
Old Neil wrote: Can't i put a r7me gearbox into my early jimny, is the later transfer case separate like my early jimny
- Thank you received: 1999
12 Jul 2020 17:29 #224914
Replied by Lambert on topic Re:Re:G series to M series motor swap
Sorry I thought you started with an older shell.
12 Jul 2020 21:14 #224968
by Busta
Replied by Busta on topic G series to M series motor swap
Are we sure the bell housing is different between G and M series engines? I have both so I will get some pictures to compare.
I know that the G16 bell housing is different to the G13, but that suggests to me the G13 and M13 are more likely to be the same than different again.
The following user(s) said Thank You: Old Neil
13 Jul 2020 11:49 #224988
by Keithy
Replied by Keithy on topic G series to M series motor swap
Chassis is the same.....James has an M13A in his originally G series car.....turbo and intercooler fitted too it has a Megasquirt ECU controlling it.
Not sure if the intermediate propshaft is different.
Nothing is impossible.
Time to create page: 0.411 seconds
