Broken 4wd Jimny 2002
  • Ipplepen
11 May 2009 14:38 #673 by Ipplepen
Replied by Ipplepen on topic Re:Broken 4wd Jimny 2002
Hello again
Now gone full circle and am convinced its the hubs - briefly managed to get 4wd selected so have be able to dismiss a CV problem.
If I want to put manaul hubs on - can you point me in the right dirction please? Either new or can I use SJ ones?
Thanks
Andy
11 May 2009 14:45 #674 by mlines
Replied by mlines on topic Re:Broken 4wd Jimny 2002
SJ hubs (either new such as the WARN ones or second hand) fit with a little modification. As I understand it the lip on the hub nut, designed to hold in the vacuum, prevents the SJ hubs from mounting directly. You can either make up a 5mm spacer ring or you can grind the lip off.
This is only what I have gathered from other people never having done it myself so you may want to check elsewhere.
  • Baz2236
12 May 2009 17:33 #681 by Baz2236
Replied by Baz2236 on topic Re:Broken 4wd Jimny 2002
I fitted non free wheeling SJ hubs to my Jimny I just grinded the big wheel bearing nut down there is a little lip in the nut I used that as my mark and just grinded round that also removed all my vacum pipes that run along the axle and closed up the pipes on the hubs to stop water / mud getting in. Since that I can always guarentee I am in 4wd. It will increase wear on the front prop diff etc,
  • Ipplepen
12 May 2009 18:27 #682 by Ipplepen
Thanks for that - I have good some second hand manual hubs on the way - I think I will fashion a spacer in the first instance to check all works OK - If I can get a 5mm spacer milled (I have a friend!)that will be my solution. If not - where did I put my grinder!
Thanks for the info
Andy
Time to create page: 0.296 seconds
