Jimny is pulling right after 2" lift
- shaharonm
21 Jun 2020 14:09 #223821
by shaharonm
Jimny is pulling right after 2" lift was created by shaharonm
Hi All,
I've installed in my new Jimny (gen 4) 2 inch lift kit of X-Shock Dakar. After lifting the car is pulling to the right.
The car is 1 month old, so other than that everything is new. The steering wheel is also seems to be centered.
Do I need to align something after lifting?
I remember that in my previous car (gen 3) I had to adjust the tie rod to center the steering wheel..
Thanks,
Shahar
Thanks,
Shahar
- X8GGY
21 Jun 2020 16:31 #223827
Replied by X8GGY on topic Jimny is pulling right after 2" lift
Have you contacted the supplier?...
- Johnniehec
- Thank you received: 56
21 Jun 2020 16:33 - 21 Jun 2020 16:34 #223828
by Johnniehec
Replied by Johnniehec on topic Jimny is pulling right after 2" lift
Hi did you fit adjustable panhard rods? If not you need to fit them and adjust so the axles are centred again. Yes that’s why the steering wheel will be off centre. You need to adjust the steering bar after you’ve re centred the axles.
Last edit: 21 Jun 2020 16:34 by Johnniehec. Reason: Spelling
- shaharonm
21 Jun 2020 17:29 #223831
by shaharonm
Replied by shaharonm on topic Jimny is pulling right after 2" lift
Thanks guys.
I didn't replace the panhards. As far as I know they are replaced for lift larger than 2 inch..
Actually the steering wheel is centered. Also I measured the toe and it seems ok.
Maybe the drag rod should be adjusted?
21 Jun 2020 17:50 #223832
by 300bhpton
Replied by 300bhpton on topic Jimny is pulling right after 2" lift
Did you change wheels and tyres too?
- shaharonm
21 Jun 2020 18:16 #223835
by shaharonm
Not yet. Still with stock tyres. Unfortunately there is no legal way in Israel to replace to normal tyres.
