Recovery points
  • Bigchridy
27 Nov 2010 21:10 #6646 by Bigchridy
Recovery points was created by Bigchridy
I'm after some sort of recovery points for the Jimny. Just wondering what other people have fitted to their trucks. Eventually I will be getting a front winch bumper and hd rear bumper but for now I'm keeping the standard bumpers. I will be off roading the truck with the standard bumpers so will need some way of been recovered. I've seen weld on tabs which look ok but I'm not sure where is the best place to weld them!:(
  • darthloachie
27 Nov 2010 22:09 #6653 by darthloachie
Replied by darthloachie on topic Re: Recovery points
  • Bigchridy
28 Nov 2010 10:37 #6661 by Bigchridy
Replied by Bigchridy on topic Re: Recovery points
darthloachie wrote: Martin does this rear one
store.bigjimny.com/index.php?act=viewProd&productId=11
I'd seen that one in the shop but I'm unsure where and how it mounts.
  • adamjimny
28 Nov 2010 11:44 #6665 by adamjimny
Replied by adamjimny on topic Re: Recovery points
just bolts around the chassis and points down so tow ropes do not contact the original bumper. they will serve you well and they are cheap really
  • mcjimny
28 Nov 2010 19:38 #6723 by mcjimny
Replied by mcjimny on topic Re: Recovery points
For the front i use the standard points but use a bridle across them to halve the load that each one sees. I dont use the hole you can see either, theres a bigger one higher up which means i can use beefier shackles, the only problem is that if your not recovered level it pulls on the bumper and gave mine droopy look(after a recent "issue" with the rear of a disco its not a big issue for me) and you need to put the strap on before you set off as they're a nightmare to get to when your stuck!
If you look up a thread on difflock by lifechooser it shows the best solution i've seen by far - they come from japan though so will cost £££'s
28 Nov 2010 19:48 #6725 by mlines
Replied by mlines on topic Re: Recovery points
I have been trying to sort a front one out forever.
I have not got a standad Jimny so the front is different so I cannot use mine as a template. I need someone local to Reading with a STANDARD Jimny (standard bumper) fitted so I can take some measurements and then build and fit a prototype etc. So it will need some trips to me in Reading on a couple of occasions. The benefit is that you will end up with a front recovery point (or two if we create both a left and right one)
Time to create page: 0.156 seconds
