Not sure what this is?
- Reason2doubt
30 May 2020 18:51 #223035
by Reason2doubt
Not sure what this is? was created by Reason2doubt
Hi all,
In the middle of a small job and ended up removing the following item:
I'm not completely sure what it is... I did a search on the part number which seemed to indicate '4x4 canister' which has me thinking it is something to do with the vacuum system (but I could be completely wrong).
This made me wonder, can I remove it all together seeing as I have manual hubs now? If so - does anyone have any advice on what to do with the two pipes going into it?
Thanks in advance & sorry for the simple question. Kind of prefer to hear it from someone on here for confirmation...
- Jcg1694
30 May 2020 19:33 #223036
by Jcg1694
Replied by Jcg1694 on topic Not sure what this is?
Looks like an old fuel/oil filter to me pal? I could be mistaken though of course
- Thank you received: 1999
30 May 2020 19:56 #223037
Replied by Lambert on topic Not sure what this is?
Yes it is the vacuum can. Unnecessary if you have manual hubs.
The following user(s) said Thank You: Reason2doubt
- Reason2doubt
30 May 2020 21:25 #223038
by Reason2doubt
Cheers mate! Always nice to have it verified by someone.
Replied by Reason2doubt on topic Not sure what this is?
Lambert wrote: Yes it is the vacuum can. Unnecessary if you have manual hubs.
30 May 2020 23:05 #223039
by ahtr
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Replied by ahtr on topic Not sure what this is?
It looks more like a fuel vapour filter/charcoal cannister to me, from an earlier Jimny with single cam engine?
Doesn't look like anything to do with the vac system, the small vac tank that lives behind the wing only has one pipe to it.
31 May 2020 05:54 #223041
Actually that is a very good point where did you find that item, if it was in the engine bay its NOT the vacuum canister. Sorry to mislead you.
Time to create page: 0.345 seconds
