Engine oil leak !
  • M-B-E
19 May 2020 16:42 #222545 by M-B-E
Engine oil leak ! was created by M-B-E
Hey everyone,
First time posting on the site but I could really use some help .....
I got 2004 jimny which has a oil leak. From what I can tell it’s coming from between the sump and the bell housing. Am I right In saying that this means the rear crank seal has gone ? Is there any tips you have for finding the definite cause for the oil leak ?
Also if it is the rear crank seal, how much of a pain is it to do ? I’m pretty capable with Tools and whatnot but I’m concerned it might just be better to ask a garage to sort it
Any advice is more than welcome
Thanks
19 May 2020 19:03 #222550 by Lambert
Replied by Lambert on topic Engine oil leak !
Welcome to the forum. I've not had cause to do that myself but it is essentially a bit more on top of a clutch job so if you're up for that then off you go. Personally I'd have it to the garage as I don't really consider a clutch a driveway job.
  • M-B-E
19 May 2020 19:37 #222552 by M-B-E
Replied by M-B-E on topic Engine oil leak !
Thanks for the reply and the welcome !
Iv not really got the means of being able to shift the transmission box around as it looks pretty heavy and like there’s not much space under there haha
I don’t suppose you’ve got any idea of the kind of cost they’d want for such a thing ? I guess around £500 - £600 if it’s abit more on top getting to the clutch
20 May 2020 03:19 #222558 by Lambert
I'd guess that sounds about right, depends on how well you know the garage.
20 May 2020 08:03 #222560 by Scimike
Replied by Scimike on topic Engine oil leak !
Just going to say hello and welcome as I can't add much more.
I tend to do my own clutch replacements as I have all the kit, but you are going to need a good trolley jack and 4 ramps to get the vehicle high. This assumes you can get at the shaft seal easily with the engine in place, otherwise it's an engine out clutch / seal replacement, requiring an engine hoist. Phone around for a few quotes, like insurance cost can vary considerably. If you have a trusted garage then just go with them, they are few and far between these days.
Good luck
Mike
20 May 2020 08:37 #222562 by mlines
Replied by mlines on topic Engine oil leak !
Before you do it, I would quickly check by looking behind the top of the engine. There are two leak points there, the rocker cover gasket and the Cam Sensor housing. See if there is oil around the back. It is worth a look to avoid taking the clutch apart and finding the seal is ok.
Time to create page: 0.474 seconds
