Re:Suspension Lift and Ground Clearance?
18 May 2020 04:30 #222465 by Lambert
Busta wrote: No, because armour decreases the ground clearance... A 2" lift will do more to protect the underside of the car than armour will do. But it's not accurate to say it has no negative impacts on the road. Even a 2" lift comes with compromises. For example, you have to choose between not having castor correction and retaining good articulation at the expense of vague steering, or fitting castor correction bushes and losing some of the articulation afforded by the factory bushes, but keeping the factory steering feel.
Except that armour actively lowers the centre of gravity even if only by a small amount as opposed to a lift which significantly increases the centre of gravity. Also depending on the amount of time spent off road armour is less of a compromise on road handling than a lift. Ok it reduces clearance but a moderately skilled driver can accommodate that with line choice. In mud guards will clog up and need more cleaning but on rocks they can protect vital parts from day finishing impacts. Ok guards might increase the risk of getting stuck in the first place but if they are well designed they can act as skids and ride over obstacles that could otherwise snag on the irregular shapes under the car. If there was a simple way of having a smooth surface under the entire vehicle including the axles I would have it but with live axles that is not an option.
The topic has been locked.
18 May 2020 08:59 #222469 by 300bhpton
mlines wrote: The thing is, that is driving position (positioning the wheel on a bank/trailer etc.). That is not clearance due to suspension lift.
Yes, it changes the ramp over angle, approach angle and departure angle as well as wading depth, but any measurement has to have a reference otherwise they have no meaning. The reference for clearance is flat ground.
Agreed. It was more meant as a demonstration that the diff ground clearance is not a static thing off road. And in many cases is a non issue, as the movement of the wheels/suspension tend to move it out of the way for the vast majority of the time.
18 May 2020 09:01 #222470 by 300bhpton
Lambert wrote: You are right. No amount of suspension or body lift is going to have any effect on the available ground clearance of a live axle vehicle for the simple fact that you are not raising the lowest point of the vehicle. The only way to do that is by fitting bigger tyres. Which is what the lift allows you space to do.
Respectfully I would disagree.
Take a situation like this:
The underside of the vehicle is grounded, due to insufficient clearance. A suspension lift would most certainly afford more clearance here and likely prevent damage or getting stuck. As a suspension lift would raise the chassis and body (and all those bits attached like the transmission and transfer case) and prevent them grounding.
18 May 2020 09:11 #222471 by 300bhpton
sniper wrote: I'm only on 215's which are 27.5 inches tall, a very small 45mm of lift and never had any clearance issue's driving the Peaks and Lakes.
I do have to consider my line a bit more than the big tyre cars and sometimes I might have to take a second run at a step but it has always got there.
I have found that bashing the underside of the car is more to do with speed, if I take my time, very little if any, contact is made.
Mostly down to personal choice, a standard car in good condition will drive 99% of the lanes out there.....
sniper
Off roading can depend on what type of off roading. Green lanes are technically roads. Although we normally label them as "off" road. That said, laning really should not be that challenging. If they are, then it probably isn't part of the lane. The biggest hurdle is likely deep ruts, which can cause something on smaller wheels to ground out more easily. Be it a Freelander or a Jimny.
But off roading takes many forms.
My Jimny is stock and going slowly has resulted in grounding and clearance issues off road. So I disagree it is purely a speed thing. The Jimny has a relatively short wheelbase, although still runs small tyres. e.g. an 88" wheelbase Land Rover would have had at the smallest a 205 sized tyre and more than likely a 7.50 x 16, the bigger tyre effectively increasing the ground clearance.
This was not caused by ruts/tramlines, but breakover angle:
And approach angle:
A suspension lift would help in both instances.
18 May 2020 09:19 #222472 by 300bhpton
kirkynut wrote: t just doesn't increase overall ground clearance.
Then maybe the question really is. Is there actually such a thing as "overall" ground clearance. Or simple different types of ground clearance. For instance if you had a sill/chassis rail hung up on a boulder or tree stump. Wouldn't the obvious thing to say be; it didn't have enough clearance.
18 May 2020 11:41 #222477 by sniper
All the lanes I drive are legal and you'd be surprised how many of them are quite challenging, even impassable to your car.... YouTube Parkamoor & Gatescarth Pass, you'll see how challenging they are. Multiply that considerably in Wales, where winches are often needed. All on legal lanes.
None of the forum members that I have driven lanes with would entertain going "off piste".......Mud plugging is for pay and play sites only or if you are lucky enough to have permission to drive on private land. Cross country trials are all held on private land.
sniper
Time to create page: 0.209 seconds
