Radius Arm Bracket Bolt Torque
- Thank you received: 633
07 Mar 2020 13:15 #219548
Radius Arm Bracket Bolt Torque was created by Soeley
Does anyone know the correct torque setting for the front and rear radius arm bolts? I am about to fit my guards and would like to tighten the new bolts up correctly. I have looked on
HERE
and i presume "Rear Trailing arm" and "Leading arm" are referring to radius arms.
Rear trailing arm No.2 nut 70.0 lbf-ft
Rear trailing arm No.1 nut 54.0 lbf-ft
Which would my nut be 1 or 2?
For the front i'm guessing rear nut?
Leading arm front bolt 70.0 lbf-ft
Leading arm rear nut 54.0 lbf-ft
Any help appreciated.
07 Mar 2020 14:08 #219551
Replied by Soeley on topic Radius Arm Bracket Bolt Torque
Oh, and should it be torque up with weight on wheels?
07 Mar 2020 16:34 - 07 Mar 2020 16:35 #219554
Replied by mlines on topic Radius Arm Bracket Bolt Torque
The naming is misleading.
Basically the axle end is 70ftlb and the chassis ends are 54ftlb
Last edit: 07 Mar 2020 16:35 by mlines.
07 Mar 2020 19:58 #219560
Thanks Martin 54 is the one I went with going off the Leading arm terminology. If you'd have come back with the 70, it would be just a matter of re-torquing.
08 Mar 2020 20:27 #219602
by kirkynut
Replied by kirkynut on topic Radius Arm Bracket Bolt Torque
I've always done them up FT.
You can use your imagination as to how tight FT is.
- Max Headroom
- Banned
- Thank you received: 216
08 Mar 2020 20:36 #219603
by Max Headroom
Replied by Max Headroom on topic Radius Arm Bracket Bolt Torque
Sheared off, then half a turn backwards should do it. (Thats more than five white knuckles)
Time to create page: 0.101 seconds
