Stuck in 4WD-L any help?
17 Feb 2020 20:42 - 17 Feb 2020 21:19 #218671 by fishjoe
Replied by fishjoe on topic Stuck in 4WD-L any help?
Update: First of all thank you everyone for reply and comments. I'm sure they'd help in solving the problem.
However, I doubted firstly, the switches, as the 4wd mode is already in and running with no issue, if its the switch it should have been problem when I tried to put the 4wd in, at least indicators would somehow flashes, even if it broke when I was already in 4wd, it should some more warning lights. But in my case the Jimny in 4wdL functioned normally. Yellow "L" indicators only flashes when I tried to change it to 4wd from 4wdL and nothing mechanically happened, and when I push the 4wdL button to "change it back"(tells the system I tried failed then put it back), the flash stops, everything back to normal in 4wdL.
I also doubted the vacuum leak, also because it acts normal in 4wdL mode no problems no flashes at all, if the vacuum fails it would affect the free wheel hub and the whole 4wd system would show error. I did actually try to switch the mode when I turn the key to ignition but without the engine on actually (good to have a manual car), it fails to change and the green "H" pattern 4wd light start to flash not the L, I then start the engine tried again, "H" stops flashing, and everything back to beginning of the problem. So this further proves, NO or LOW vacuum would show different symptoms, not very likely to have close relation to my case.
Someone told me to reverse and brake, I tried, also drove then hard brake, and tried to drive in 4wdL then run neutral to stop, even when I jacked up the car first thing I tried is to spin the lifted wheel front and back hardly couple of times. Sit back into car and try the change, nothing happens. So I believe it was not mechanically jammed, but still big thank you.
FINALLY:
I read some other forum someone mentioned about solenoid, I thought it might be the cause. I had experience in solving solenoid issue for a starter motor, guess they somehow are similar. So before I get the switch checked and vacuum checked, I simply jacked up the vehicle and lie down of it, gave it few gentle bashes on the metal cover of the solenoids with hammer, starting again, and tried. Guess what? PROBLEM SOLVED! 5 MINS.
Of course I'm looking for a replacement solenoid and try not to use 4wd again before repaired. If have to I'd only use high speed 4WD, and only switch when completely stopped. Don't want the intermittent problem become a constant "push button and hammer bashing" 4wd, eventually one day it will refuse the bashes at all. Won't let the it come too early before parts found.
At the end I HIGHLY RECOMMEND EVERYONE TRY THIS FIRST if symptom is same, its so simple worth a try even it's actually some other issue.
Last edit: 17 Feb 2020 21:19 by fishjoe.
The following user(s) said Thank You: Al B Right
17 Feb 2020 21:43 #218675 by kirkynut
Replied by kirkynut on topic Stuck in 4WD-L any help?
Thank you for your input with what the solution was. I'm sure if will help others out in the future.
Look for a good second hand solenoid as I believe that the price of new ones will make you feel unwell from what I've read!
09 Apr 2023 13:46 #248463 by Al B Right
Replied by Al B Right on topic Stuck in 4WD-L any help?
I had the same issue with my 2007 Suzuki Jimny, I followed your recommendation, and the issue was resolved. Thanks for the logical thinking in the process.
Time to create page: 0.138 seconds
