Rough running on start
20 Jan 2020 20:19 #217465 by Max Headroom
Ok this is a bit of an intermittent issue, its happened a good few times now. When it does happen its VERY noticeable to say the least.
First start of the day - warm/dry wet/cold weather (makes no difference) car starts but runs like a bag of nails poppoing and spluttering but doesnt stall. - close though.
I usually rev through it and it eventually sorts itself out, and it's then fine for a number of weeks without any recurrence. I suspect a sensor somewhere but would like the opinion of anyone else more familiar with the Jimny than I am
20 Jan 2020 21:49 #217469 by Scimike
Replied by Scimike on topic Rough running on start
Intermittent problems are the worst, much easier if it just stops.
As a first step how about going old school and take a look at the colour of the plugs? If they all look the same then it's likely a common problem, as you say sensor etc. If one is noticeably different to the rest it suggests a localised problem, this could be plug, coil, injector etc.
At the same time check all the connectors etc for dirt or damage.
Just a starter suggestions.
Mike
20 Jan 2020 22:25 #217471 by Max Headroom
Replied by Max Headroom on topic Rough running on start
Thanks Scimike. I've not had much time the next job to do is sort the poor heater out (you probably read about Lambert's fix on his - I plan to do the same)
I have looked at a few connectors but not found anything obvious - all are in good shape - no corrosion or oil etc.
Its not due a service until May, so I'm hoping it will behave itself until then when the weather warms up a bit and I can get some more time on it myself using the light of the longer evenings
I guess I'm asking if there are any 'usual suspects' for this kind of fault.
  • skinnymik
20 Jan 2020 23:11 #217473 by skinnymik
Replied by skinnymik on topic Rough running on start
Do you have any problems starting? ie it's spinning but won't start until you give it a little gas, then runs lumpy for a few mins & then sorts itself out?
Would be good to know, as I have the same issue. Got it booked in next week.
21 Jan 2020 05:08 #217474 by Lambert
Replied by Lambert on topic Rough running on start
Dreadnaught did this a few years ago, running on 3 cylinders and popping and banging that then cleared. At the time I was using a set of aftermarket plug leads because I had been trying to find a flat spot at 2k rpm that was plug related. Anyway, so I switched to new genuine leads and bingo no more trying to run on 3. In fact I am feeling that it eventually did it while being driven not just starting and that was what triggered the fault finding. Never gave me a code though not even for a misfire. This is on an m13a vvt others may be different.
21 Jan 2020 06:37 #217475 by Max Headroom
Thanks for the replies Skinnymik & Lambert, you both have summed it up quite nicely with your descriptions.
I have no code to read and this is also on a M13A VVT.
No problems starting Skinny - it starts alright (though it has a new battery in it, so all is well there)
Like you Lambert I do feel I'm losing a bit of power sometimes during a journey - notably on hills; It doesn't seem as smooth running as my neighbours car but she has a G type engine in hers so I can't make any comparison
I'll take a look at the plugs and investigate changing the replacing plugs and leads - theres been some talk of particular types of plugs but I'll have to look for it unless you guys know whats best?
Time to create page: 0.104 seconds
