Re:Engine for jimny
- Benji2020
20 Dec 2019 17:30 #216635
by Benji2020
Engine for jimny was created by Benji2020
Hi all new to the jimny scene just trying to find out what engine goes in my 2003 02 soft top jimny.. basically killed mine and need a new engine but getting confused as what is easy to fit or identical replacement
Cheers
Cheers
- Thank you received: 706
20 Dec 2019 17:37 #216637
Replied by jackonlyjack on topic Engine for jimny
Should be G13bb
Does it have a large black cover on front of engine over cam belt
Maybe says 16V on it
- Benji2020
21 Dec 2019 06:53 #216656
by Benji2020
Replied by Benji2020 on topic Engine for jimny
Can u fit the g16bb engine in or is there any other engines that’s are east to fit without any major modofcations
21 Dec 2019 09:07 #216657
- Benji2020
22 Dec 2019 11:25 #216695
by Benji2020
Replied by Benji2020 on topic Re:Engine for jimny
I have decided to just put a like for like engine in.. my only question is will any g13bb engine fit or do I need one out of a soft top as I have read that there are to different types of this engine
Thanks ben
Thanks ben
22 Dec 2019 12:09 #216697
by facade
Replied by facade on topic Re:Engine for jimny
The two different types are
one has a crank sensor and a cam sensor
one has just a cam sensor
The camshaft pick up sprocket is different between the two, so if you get the wrong one either the cam has to be swapped (and I believe you have to drill the block if you need a crank sensor), or you can remove the pick up sprocket and replace it, but it has to go on in the right place. There is a post on here about swapping it.
No-one really knows which engine you have, the soft top could have either, you need look for the crank sensor to tell.
The following user(s) said Thank You: Benji2020
Time to create page: 0.096 seconds
