Your opinions
11 Dec 2019 19:45 #216409
by Fossie
Replied by Fossie on topic Your opinions
Thanks for the Imput, the info was passed on and we'll start with some catacleaner as it can't harm.
When we know so will you.!
- Thank you received: 664
12 Dec 2019 12:02 #216425
Replied by DrRobin on topic Your opinions
Is the steering driven from the vacuum? If so, this might indicate an inlet problem. The steering might be a red herring, apparently how heavy it is varies a lot.
I would check the plugs, they will tell if it is rich or lean.
Timing, was it sluggish before the CAM belt was changed?
It could be a brake binding, that might make the steering feel heavy. If you get up to speed, roll the throttle off and push in the clutch does it slow down quickly, like it's been braked?
Only other thing I can think off, it isn't staying in 4x4 is it? I don't know enough about how the vac hubs work to know if this is possible, but that would certainly make it feel heavy.
10 Jan 2020 23:37 #217162
by Fossie
Some good thoughts here, But for now we went for easy option as she( daughter) lives in the oolu.
Anyway put catacleaner in and tank of fresh petrol and it ran better , but it seems when the tank is full it runs better, but 1/2 tank area back to sluggish.....
If it was a vent problem it would misfire or stall.
Fuel filter? = pressure.
- Thank you received: 1983
11 Jan 2020 04:18 #217163
Replied by Lambert on topic Your opinions
The fuel filter is an in tank mesh type and is not given to blocking in the same way as the inline ones do. It's also a tank out job to replace the filter/pump assembly which is as much of a pain as it sounds. Unless someone has randomly fitted an auxiliary inline filter?
- CC Baxter
11 Jan 2020 09:39 #217168
by CC Baxter
Replied by CC Baxter on topic Your opinions
Is the tank breathing properly? Could be the EVAP cannister, if you can vent the tank with an old fashioned drilled fuel cap ( or some other unmentionable method) that might give you some indication.
Chris
Chris
11 Jan 2020 12:42 #217170
by RainerK
Replied by RainerK on topic Your opinions
Maybe you could try to open the fuel cap every 60 miles for checking if it is an underpressure in the tank.
Time to create page: 0.173 seconds
