Slow wipers
  • wejxf03
02 Dec 2019 21:32 #216163 by wejxf03
Slow wipers was created by wejxf03
I recently took my 2001 auto Jimny out for a spin and the wipers worked very slowly across the screen but speeded up a little when I used the washers. They did speed up a bit after use for a while.
Battery/alternator are good.
Just wondering if the motor and/or wheel boxes needed greasing?
Anyone else had this and know the cure.
Thanks in advance, John
03 Dec 2019 05:24 #216169 by Lambert
Replied by Lambert on topic Slow wipers
Stupid question but was it raining? If i leave my wipers on when I go under Asda's car park they will slow significantly as they dry the screen and speed up again as the rain resumes when I go back outside.
The following user(s) said Thank You: wejxf03
  • wejxf03
03 Dec 2019 10:08 #216190 by wejxf03
Replied by wejxf03 on topic Slow wipers
Yes it was lightly raining and did get better when I used the washers so perhaps it's normal, just different to modern cars.
03 Dec 2019 16:33 #216206 by Lambert
I think it can also be a problem with older more worn blades, certainly mine always seem a bit stronger when the blades are new. Or that is psychological.
  • wejxf03
03 Dec 2019 17:47 #216214 by wejxf03
Thanks, blades look in good nick but worth a go at changing I guess.
08 Dec 2019 21:03 #216303 by Fossie
Replied by Fossie on topic Slow wipers
Hi there did we a resolution to this query, I ask because I visited my daughters Jimny in Scotland to day , the first time since she took delivery a month ago.
Anyway as I test drove it .....the wipers are slow, on 2 speed they are what you'd expect from normal speed.
The blades are fine and I can confirm it was raining .......oh yes it WAS raining.
Time to create page: 0.099 seconds
