2005 M13A vvt to M16A vvt swap, what engine years are suitable?
- Jimny Sprocket
24 Nov 2019 22:19 #215937
by Jimny Sprocket
2005 M13A vvt to M16A vvt swap, what engine years are suitable? was created by Jimny Sprocket
I’m just about ready to swap to 1.6 engine, how late a model year can I go so it all remains plug and play? I’ve noticed some later engines have 4 ignition coils instead of 2, I know that swapping the original rocker cover will resolve this, is there anything else to watch for, crank or cam sensors, fly by wire throttle?
Any advice appreciated.
Sent from my iPad using Tapatalk
25 Nov 2019 07:45 #215941
Replied by Daniel30 on topic 2005 M13A vvt to M16A vvt swap, what engine years are suitable?
25 Nov 2019 07:51 #215943
Replied by Riccy on topic 2005 M13A vvt to M16A vvt swap, what engine years are suitable?
upto 2010. After that year there is a different trigger wheel for the VVT.
- Jimny Sprocket
25 Nov 2019 10:24 #215947
by Jimny Sprocket
Replied by Jimny Sprocket on topic Re:2005 M13A vvt to M16A vvt swap, what engine years are suitable?
Thank you both.
- quadfucius
03 Jun 2020 06:56 #223189
by quadfucius
Replied by quadfucius on topic Re:2005 M13A vvt to M16A vvt swap, what engine years are suitable?
Did you go for a pre-2010 or a post 2010 in the end?
03 Jun 2020 11:50 #223215
Replied by yakuza on topic 2005 M13A vvt to M16A vvt swap, what engine years are suitable?
Possible to swap the m13 trigger wheel over like on the G13BB swaps?
And rocker cover must be swapped from the m13 anyways to get the dip stick down the correct place.
Mine is a 2009 Liana. Works brilliantly.
Time to create page: 0.157 seconds
