4WD-L not working
13 Nov 2019 12:51 #215602
by Velocette
Replied by Velocette on topic 4WD-L not working
Have you tried putting it in neutral as well as depressing the clutch. Mine will only work if I do.
The following user(s) said Thank You: Wailin
13 Nov 2019 18:38 #215609
Replied by mlines on topic 4WD-L not working
People are getting mixed up.
Its an earlier lever based model. It has no choice whether it goes into 4wd Low or not. Move the lever to the low position = its in low. its entirely mechanical. Whether it INDICATES that this has happened depends on any switches and lights working. Some versions do not have all the lights anyway
16 Nov 2019 09:50 #215683
by Wailin
Replied by Wailin on topic 4WD-L not working
Thanks Martin, I was thinking there was some confusion about the switch alright. So it might be working but just no visible indicator to show it's in Low? Is it a very noticeable difference as I don't seem to notice anything in the revs or power?
16 Nov 2019 09:52 #215684
by Wailin
Yes, always in neutral and clutch depressed before moving to the low position.
Velocette wrote: Have you tried putting it in neutral as well as depressing the clutch. Mine will only work if I do.
- Thank you received: 1860
16 Nov 2019 10:16 #215686
Replied by Lambert on topic 4WD-L not working
In low range your top speed per gear is nominally half that of high range. It is very obvious.
Time to create page: 4.360 seconds
