Brake caliper rust and paint
10 Oct 2019 13:35 #214564 by Bosanek
The brake calipers on my 7-year old Jimny 3 are completely and severely rusted.
Is that normal for 7 year old factory fitted brake calipers?
Which paint would be recommended as a durable solution after cleaning the rust off?
10 Oct 2019 16:00 #214572 by Lambert
Yes perfectly normal. Though I did replace mine at 8 years old as the rust had migrated into the slides for the bolts and I was stripping them and cleaning them almost every month towards the end. As for paint any Very High Temperature paint will work but honestly I don't see much point. Painted calipers are only ever vaguely suited to Porsche cars with carbon ceramic brakes and then not really.
10 Oct 2019 18:24 #214573 by Max Headroom
Used THIS stuff on my SAAB calipers and it stayed on superbly.
If you go down this route, I would suggest cleaning and degreasing, and de-rusting as much as possible before using the can of pre-cleaner provided.
10 Oct 2019 19:12 - 10 Oct 2019 19:13 #214578 by Scimike
+1 for the above product ^^^^^^^^
Sure I obtained from a local Eurocarparts when one of their never ending sales was favourable for paint products. It's on my Jimny and it's lasting quite well. Cutting the rust back (but not removing totally) takes the time, application and drying times are quick. Used about a 1/4 of a can on the two calipers. You can't really see the results on a Jimny which is fine so long as your aim is to hold back the rust and make working on the brakes a little cleaner next time.
Last edit: 10 Oct 2019 19:13 by Scimike.
  • Jimx5
10 Oct 2019 20:51 #214583 by Jimx5
Replied by Jimx5 on topic Brake caliper rust and paint
Hammerite silver smooth is just as good.
12 Oct 2019 20:13 #214680 by Paul4A
Replied by Paul4A on topic Brake caliper rust and paint
Or get them professionally rebuilt at say www.biggreddemo.auto-guru.uk/ then you know they’ll work and last for years
Paul
1999 T registered Jimny. Early G13BB SOHC engine.
Time to create page: 0.807 seconds
