Winches
  • GF68
10 Oct 2019 13:00 #214561 by GF68
  • GF68
10 Oct 2019 13:04 #214562 by GF68
Replied by GF68 on topic Winches
No eBay APP ID and/or Cert ID defined in Kunena configuration...and be careful which shackles you buy, I made the mistake of buying unrated ones first, just because they were the right size for the holes in the rescue points.
Discovered later that rating was very important and binned them to get smaller, but rated, bow shackles.
Lots of videos on YouTube that explain how to work out what you need.
I bought these
as they seemed a fair price and came quickly.
10 Oct 2019 20:15 #214582 by jackonlyjack
13 Oct 2019 11:54 #214694 by kirkynut
Replied by kirkynut on topic Winches
To help with the bits that have not been covered yet, this us the Rolls Royce of solenoids that can be located out of harms way under the bonnet with extended wiring:
www.devon4x4.com/albright-contactor-heavy-duty.html
You need thick cabling between the battery/winch/solenoid for the high amps the winch can draw under load. See:
www.electricwinchshop.co.uk/0-5m-35mm2-solenoid-extension.html
Jimny Bits do a battery relocation tray for a bigger battery except for some cars with ABS and Aircon.
Which battery is a topic of its own that has been covered on here is you have a search.
You need a hawse fairlead for a rope and deals can often be had when buying both at the same time.
You need no less than 9mm thick rope. This is what I have and it has done well:
www.electricwinchshop.co.uk/winch-access...m-standard-hook.html
Here's a cheap fairlead from the same company to save postage.
www.electricwinchshop.co.uk/109mm-hawse.html
I know that the rope is not cheap but don't buy a really cheap one or you'll regret it.
As your winch is an unknown quantity, you might want to strip it down and grease it up inside and check the condition of the motor and its contacts, brushes etc.
13 Oct 2019 12:46 #214695 by Reason2doubt
Replied by Reason2doubt on topic Winches
kirkynut wrote: To help with the bits that have not been covered yet, this us the Rolls Royce of solenoids that can be located out of harms way under the bonnet with extended wiring:
Excellent info! Cheers
14 Oct 2019 12:50 #214746 by Roy
Replied by Roy on topic Winches
Hi Kirkynut have just had Winch checked and one of the magnets is cracked so unfortunately not viable to repair shame really as the rest is good(spares maybe) anyway been looking at winches and seeing as I'm not going to do any serious off roading don't really want to spend a fortune, maybe a 3000 lb would be useful if needed. Seen loads on fleabay, are Rhino any good, seem good value, I know you get what you pay for, suggestion would be helpful.
Time to create page: 0.156 seconds
