Re:Numberplate meltdown!
07 Oct 2019 15:56 #214420
Replied by Daniel30 on topic Numberplate meltdown!
Blimey that must have smelt bad, a exhaust hanger broke on my exhaust and was just starting to touch the rear bumper.
- wombat
07 Oct 2019 16:45 #214426
by wombat
Replied by wombat on topic Re:Numberplate meltdown!
Had exactly the same problem with my last two jimnys, and as Lambert said, for not much more the genuine suzuki parts do seem to last longer
Sent from my F5121 using Tapatalk
- mickt
08 Oct 2019 13:54 #214475
by mickt
Replied by mickt on topic Re:Numberplate meltdown!
No report of smell so I assume the fumes were blown away as she drove.
09 Oct 2019 17:31 #214522
Replied by yakuza on topic Re:Numberplate meltdown!
Original ones got heat shields where they need to be, and they will fit better so the distance to other parts will be sufficient. I have messed around with mine up front with the cat part. So it is now an inch or so longer cause I haven't been precise with the dimensions. I Will have to check for this..
- mickt
10 Oct 2019 08:50 - 10 Oct 2019 08:54 #214547
by mickt
This one had the heat shield but it only covers the upper surface shielding the floor, not the rear horizontal surface which is where the holes are. I know it is a poor photo but you can make out the shield and the holes on the last two frames.
Last edit: 10 Oct 2019 08:54 by mickt.
- mickt
10 Oct 2019 09:46 #214551
by mickt
One for mlines Is it possible for you to delve into the IPC and show the picture of the rear bumper mountings for me?
Also is it normal on the forum as a whole to have to log in everytime you enter the system. It used to remember your log in especially if you left and then went back on in the same day but today I have done that 4 times and each time I have to relog! Or is it my computer?
Time to create page: 4.170 seconds
